Like Tree5Likes
Old 03-29-2004, 06:41 AM   #2851
David Joor's Avatar
R/C Tech Charter Subscriber
Originally posted by Frank McKinney
A lighter driveshaft and input shafts would at best induce more torque steer, or introduce it in a car/on a track that previously had none. Comparing the weight of the motor armature and all the other longitudinally spinning parts, you should want to go slightly heavier on the drive shaft if anything. Why else would TC3 team drivers be using aluminum drive shafts, other than the carbon shafts breaking?
You may be correct but the main reason the TC3 guys run the aluminum shafts is because they run a lot more true than the carbons. A slight wabble in the shaft and you loose a ton of efficiency. This is to go without saying that the carbons had a tendency to break due to flex.
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 03-29-2004, 06:57 AM   #2852
The Teacher's Avatar
Trader Rating: 47 (100%+)
Proteus, did you hook a brotha up???
David Joor, wish you could have ran the HPI at the Nats, I really needed setup help. That BMI chassis looked like the way to go, do you know how we can go about getting one???
The Teacher is offline   Reply With Quote
Old 03-29-2004, 07:01 AM   #2853
STLNLST's Avatar
Trader Rating: 19 (100%+)
Default Re: Lengthy....
Originally posted by RCBuddha
Well, good luck to you and your Shumacher....perhaps you need to be focusing on your car and not other peoples....
I have no choice but to worry about my buddies cars. When they don't finish the race that we're in I ask what happened. I was going to try the Pro4 myself before the Schumacher deal but there's nothing that I can do about that now. Good luck to you and I'm sure that BIGDOG will be fine so long as he doesn't hit the boards....
...speaking of boards what type of barriers are most people racing with? Our outdoor track has boards which will seperate the men from the boys. Some guys race or tracks that have burms like the Tamiya track. This may also be the reason why some have had problems and others haven't.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-29-2004, 07:10 AM   #2854
Frank McKinney's Avatar
David - true that! But I didn't want to comment on the nature of the carbon HPI shaft (whether it is out of true or not) before I saw one
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 03-29-2004, 07:29 AM   #2855
David Joor's Avatar
The Teacher - I already have a great setup posted for the Pro4 on carpet for club racing traction levels. If you haven't been to a national carpet race in mod, than you must understand that a great setup for a club level race is about 50% right when you get to a national level traction track. The car will get on two wheels every turn or spin out. Just requires some tweaks here and there.
Frank - your a funny man! I have no doubts in the trueness of an HPI product.
Old 03-29-2004, 07:42 AM   #2856
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I race on a board track.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-29-2004, 07:46 AM   #2857
David Joor's Avatar
Board tracks have more traction than the concrete tracks (cleveland and snowbirds are board tracks), but they still don't generate the amount of traction on a local level. Mainly it is from the few hundred cars running on the carpet all day with a ton of paragon. It would be like getting a sprayer filled with paragon and spraying the track down with it
BTW - Stock is not nearly as affected as mod.
Old 03-29-2004, 07:57 AM   #2858
rc-zombies's Avatar
Originally posted by acutts
Would using the graphite back plate for the Evo3 on the Pro4 one-way help with gear problems?
I posted a pic of the evo3 plate mounted on the Pro4 one-way a few pages back..... haven't had a chance to run it under race conditions yet...been too busy with family stuff lately...
Old 03-29-2004, 07:57 AM   #2859
rayhuang's Avatar
David Joor-Good to meet you this weekend. Glad your home safe and sound. The only problem with building board tracks right now is lumber prices are through the roof. Price out what it costs to lay down a wood subfloor-then add labor to install it.......
But-no doubt-a board track has mad grip-even for a club race compared to one layed down on concrete.
Talk to ya soon,
Ray
Old 03-29-2004, 08:01 AM   #2860
kewdawg's Avatar
Default new parts posted by Proteus, abroad
Those aluminum shock bushing will definitely help! The stock plastic ones, deform a little too easy. I'm definitely gonna get that graphite main drive shaft - its DA'... HEAT!!
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 03-29-2004, 08:19 AM   #2861
Send a message via Yahoo to Doug Gaut
David and others, can you suggest a spare parts list for a racer that does not have HPI support in the area? Looking at getting a car but will need to stock the necessary parts to support the car. Thanks.
Doug Gaut is offline   Reply With Quote
Old 03-29-2004, 08:27 AM   #2862
David Joor's Avatar
Ray it was a pleasure as well.
Doug - I would get the beveled diff gears, steering blocks, and if you want to always run the same caster blocks, I would get an extra set to be safe. The arms are durable compared to any other car on the market, but that could be a safe bet as well.
Old 03-29-2004, 08:55 AM   #2863
kewdawg's Avatar
Anyone know the web address for Square R/c? If, there is one available.
Quinn Moon
Old 03-29-2004, 08:59 AM   #2864
V12
V12's Avatar
http://www.rc-square.com/
V12 is offline   Reply With Quote
Old 03-29-2004, 09:00 AM   #2865
RCTech Member #2
TSR6's Avatar
PRP is working on an aluminum back plate.
When I was talking about a "board" track earlier, it was in responce to STNL's question about the barriers, not the carpet's base.
Troy
RCTech Member #2
