Old 03-29-2004, 01:42 AM   #2836
Send a message via AIM to Proteus
more
Proteus is offline   Reply With Quote
Old 03-29-2004, 01:43 AM   #2837
more....
Old 03-29-2004, 01:45 AM   #2838
one more..
Old 03-29-2004, 01:51 AM   #2839
Beeb's Avatar
Send a message via AIM to Beeb
Originally posted by Proteus
more things
I've seen these at my LHS (purple motor screws), but everything else you've shown is MIA.
Beeb is offline   Reply With Quote
Old 03-29-2004, 01:52 AM   #2840
hehe...and more
Old 03-29-2004, 01:54 AM   #2841
Old 03-29-2004, 01:55 AM   #2842
last one....
Old 03-29-2004, 01:58 AM   #2843
Beeb's Avatar
I'd like that Graphite drive shaft!
Old 03-29-2004, 03:16 AM   #2844
acutts's Avatar
Thumbs up
That Drive Shaft looks really good. Not sure the rest of that stuff would give any performance enhancement.
acutts is offline   Reply With Quote
Old 03-29-2004, 05:17 AM   #2845
black-knight's Avatar
R/C Tech Charter Subscriber
I been enjoying my Pro4 so much i decided to buy a 2nd kit, construction started tonight, nothing will lack on this BKv2 Pro4
Pic attached.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 03-29-2004, 05:53 AM   #2846
RandyB's Avatar
That graphite shaft is really sweet!
I am thinking about getting the tobee craft bomb bat shaft.
RandyB is offline   Reply With Quote
Old 03-29-2004, 05:56 AM   #2847
acutts's Avatar
Would using the graphite back plate for the Evo3 on the Pro4 one-way help with gear problems?
Old 03-29-2004, 05:59 AM   #2848
Frank McKinney's Avatar
A lighter driveshaft and input shafts would at best induce more torque steer, or introduce it in a car/on a track that previously had none. Comparing the weight of the motor armature and all the other longitudinally spinning parts, you should want to go slightly heavier on the drive shaft if anything. Why else would TC3 team drivers be using aluminum drive shafts, other than the carbon shafts breaking?
Personally I'd recommend sticking to the options that Hara/Thad use...which is to say, none
That said, I did put the RC Screwz stainless steel screw kit on my car, mainly just for a little bit of bling. I figure that should be it for me as far as options go, other than a motor heatsink.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 03-29-2004, 06:01 AM   #2849
Probably not - do the hot water soaking bit and you *should* be okay, although a hard hit on the front end when using a front one-way could still bust the gears. Try a front diff first if you can.
Old 03-29-2004, 06:11 AM   #2850
acutts's Avatar
Smile
I agree Frank....! I used to run the Yoke SD but put so much bling on it that the setup went to hell as I had all these different parts on.
The only thing I have done to my Pro4 is use titanium screws and I am going to keep it that way. I run stock so for me cells and motors are a better place to spend ones cash ...!
