Old 03-26-2004, 12:53 PM   #2776
Default complete ball diff
hey i'll be getting a couple of the complete ball diff for the pro4 into my store this coming monday. PM me if anyone needs one.
All Speed Hobbies is offline   Reply With Quote
Old 03-26-2004, 01:09 PM   #2777
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by Beeb
Thanks for mentioning that! I went and checked my bars and they wouldn't rotate at all. Now I know what they meant by "play." I thought it meant left/right movement.. not up/down.
yeah, the swaybars should be able to rotate freely when disconnected from the arm. If they don't, you have 'em to tight.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-26-2004, 02:15 PM   #2778
Super Steve's Avatar
Send a message via AIM to Super Steve
darn... the fantom bearing oil is thin oil...
The oneway slips worse now...
Do i take the drivecup out, oil the shaft of the drivecup and put it back in?
How about that white grease that the kit includes?
Super Steve is offline   Reply With Quote
Old 03-26-2004, 02:16 PM   #2779
rc-zombies's Avatar
sometime I use the grey grease for my one-way...
Old 03-26-2004, 02:18 PM   #2780
RCBuddha's Avatar
Trader Rating: 33 (100%+)
steve, you may have a bad one way. Your bearing should not be moving in its housing. Try contacting HPI and seeing if you can get it replaced.
RCBuddha is offline   Reply With Quote
Old 03-26-2004, 02:37 PM   #2781
darn...
i already contacted them about missing of the droop screws, no wi have to get the oneway changed...
I will try the white grease first and then see how it slips then...
Old 03-26-2004, 02:39 PM   #2782
rc-zombies's Avatar
Default HPI BAG
Anyone interested in this HPI pitbag?
I have two and one as to go...not available in the US. and $$$$
excellent condition. no rips or tears...only been used a couple of time mainly to transport cars and tires....includes 3 boxes has HPI logo printed on them. pm me for details...
advance warning..not cheap.
so you don't have sticker shock....
Old 03-26-2004, 02:40 PM   #2783
rc-zombies's Avatar
darn...
before applying anymore grease...clean it out with some motor spray. and see how it feels...then apply the grease....
Old 03-26-2004, 02:46 PM   #2784
OSherman's Avatar
what exactly is this 'slippage' in the one way?:
A-the outdrive can actually rotate backwards in the one-way bearing?.
B-the one-way bearing is spinning/slipping in the purple hub?.
if either of those, only cure is a new unit all together..
actually, you could replace the one way bearings if you had the proper tools.. some are press fit in the hubs.... and i think some are epoxy'd in... i would rather have it replaced if need be..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-26-2004, 02:55 PM   #2785
I guess it was Problem A...
I am happy to annouce that after using the HPI white grease, there is no more slippage in the oneway.... now it locks solid whenever it's suppose to...
I am a happy camper!
I was always told not to grease or oil the oneway bearing it self in because it can slip, but i guess its backwords?
Old 03-26-2004, 02:57 PM   #2786
Zombies - I didn't get a chance to motorspray it. After my post, i went in my room to disassemble the front hub so i can take out the outdrive.
I greased both outdrives one that was slipping before had some light scratch? marks.
Old 03-26-2004, 03:02 PM   #2787
rc-zombies's Avatar
you can remove the light scratches by using auto polishing compound.. put the outdrive on a dremel or drill..put some polishing compound on a cloth and let it spin til it's nice and shinny. This works for shock shafts as well!... if you don't have polishing compound...use toothpaste. it will be nice and shinny with no cavities...
Old 03-26-2004, 03:07 PM   #2788
i will try that later when i have my car apart...
Mother's polish should be good, right?
Old 03-26-2004, 05:01 PM   #2789
stonedgti's Avatar
Trader Rating: 15 (100%+)
If any of you need a complete ball diff for the pro4 call Allen.
650-692-6180.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 03-26-2004, 07:19 PM   #2790
My first movie of the pro 4!!!
"The incident with 3PK"
http://www.rcpics.net/view_single.php?medid=26586
SEO by vBSEO 3.5.0
