Old 03-25-2004, 12:48 PM   #2731
Trinity2's Avatar
Post
Hey rc-zombies. I just got those beauties, Jets purple transponder holder and servosaver set for my Pro4 from Rcmodel.
I have to say at that quality of those parts is awsome
I will also test next week how those Speedtech`s ceramic bearings add speed to my Pro4...
I also got those extra bevelgears as well and boiled them after that
Trinity2 is offline   Reply With Quote
Old 03-25-2004, 01:01 PM   #2732
rc-zombies's Avatar
THat's great!!!...
lmk about Speedtechs ceramic bearings...I'm thinking of getting a set as well...
Old 03-25-2004, 03:21 PM   #2733
Originally posted by galway
I just spoke with speedworld hobbies and they claim that nobody in the US will have bevel gears till mid to late April. On a good note they claim they should be able to make a spacer allowing you to use a Yokmomo gear that is both stronger and readily avaiable. I sure hope they come through on this. I don't want to have to wait a month before I can get my pro4 back out there.
If you need a bevel gear, then send me a message. I might have something that I can rob some gears from.
Thanks,
Louis
BallisticHobbie is offline   Reply With Quote
Old 03-25-2004, 03:29 PM   #2734
Beeb's Avatar
Send a message via AIM to Beeb
Originally posted by TSR6
I run a Personal Transponder, It's mounted in the center of the chassis, via the two steering post screws.
http://www.rctech.net/forum/attachme...?postid=731288
I just got my personal transponder and was wondering if you've had any problems with it being mounted there? The instructions say to not mount on Carbon Fiber so I'm just wondering. I've never used a transponder before.
Thanks.
Beeb is offline   Reply With Quote
Old 03-25-2004, 03:33 PM   #2735
rc-zombies's Avatar
Thanks.
I have mine mounted there and tried it on the main chassis in front of the batteries...no problems yet...
Old 03-25-2004, 03:50 PM   #2736
Super Steve's Avatar
Send a message via AIM to Super Steve
I can't find HPI's Email address...
Anyone know what it is?
I think my car will handle funny with no droop settings...
Super Steve is offline   Reply With Quote
Old 03-25-2004, 03:51 PM   #2737
O yes,
I tried to use the Golf Tee balacing mathod, but it's so hard!...
how many trys did you take to get the car on there?
I don't think i can do it without someone holding the car and me lining the tees with my hands
Old 03-25-2004, 03:52 PM   #2738
rc-zombies's Avatar
you may have to call them direct..
Warrantee info:
http://www.hpiracing.com/warranty/warr-pts.htm
Old 03-25-2004, 04:45 PM   #2739
Cool, I am gonna wait till my friend in California on msn come online... i will get him to call hpi usa...
Anyways, after the car is all built, don't you guys find some play in the front c hubcarriers against the a arm?
man... this car is STIFF and the new body posts are super THICK for people like me
the steering is so smooth and there is alot of room for electronics. i am in love with the car!
Old 03-25-2004, 04:56 PM   #2740
Disturbing fact that i found out about my oneway..
the front right bearing slips slowly....
anyone else have this problem?
Old 03-25-2004, 05:01 PM   #2741
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Thanks.
Nope, No problems with mine, but if you are worried about it, you can always have the race director check the signal for you before the race.
Steve - Did you put the washer in between the castor block, and the arm? It's in the instructions, but I actually passed over it when building my first car. I didnt notice the washer there until I found that the car had some play, and was going to instal a teflon motor shim. With the washer there ( per instructions ) you should have just enough play to keep it from binding. Nothing to be worried about.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-25-2004, 05:15 PM   #2742
hahaha...
i just realized that also...
you use teflon washers under the motor screws on pro 4?
Old 03-25-2004, 05:19 PM   #2743
My hobbys shop doesn't have any 2mm Hex Drivers but only 5/64, whicih according to my calculations is suppose to work with 2mm...
buy it and use it to tighten my screws or wait on finishing the pro 4 around a week and half till i get the 2mm and tighten my screws then??
Old 03-25-2004, 05:22 PM   #2744
rc-zombies's Avatar
They are equal..... I use an Integy 5/64 on mine....
Old 03-25-2004, 05:23 PM   #2745
RCTech Member #2
TSR6's Avatar
hahaha...
No, I was going to use it to shim the front castor blocks, until i realized that I didnt install the washer like it says in the instructions.
Troy
RCTech Member #2
SEO by vBSEO 3.5.0
