Old 03-24-2004, 05:25 PM   #2671
Super Steve's Avatar
Send a message via AIM to Super Steve
rczombies, yesterday, when i found out i had no droop screws, I mounted the a-arms, built the very pretty shocks, CVDs and the diffs...
When I was working on the pro 4 this morning, the 2mm wrench stripped slowly so i had to stop... but now I finished half the car with my friend's 2mm L wrench (starting to strip again...)
Man.. this car is so awesome!!! servo and battery sits sooooooooo closely to the center...
My friend also gave me 4 purple wheels and 4 purple wheels with used yokomo tires... that are pretty sweet rims...
I will take pictures if i can tonight. I think i can finish the car tonight (but no sanded and CA'ed upperdeck and shocktowers. Maybe i will leave taht for the weekend)
About the droop screws, can I contact hpi to send me the set of 4 that I am missing or do I have to buy my own now?
Super Steve is offline   Reply With Quote
Old 03-24-2004, 05:29 PM   #2672
rc-zombies's Avatar
Super Steve..
yea contact HPI customer service... they'll be able to send some out to you at no charge...
Old 03-24-2004, 05:40 PM   #2673
coastaltony's Avatar
Building this kit without a 3mm tap is a no-no!
Be careful with the tap, go STRAIGHT into the holes.
Be VERY careful of the 1st thing you need to tap. It is the 4mm droop screw holes. ONLY GO ABOUT 1/2 way in. If you go all the way through, your droop
screws will be loose.
Z now I know why Tobee gave spare spacers. It is to firm up the spur gear.
coastaltony is offline   Reply With Quote
Old 03-24-2004, 05:41 PM   #2674
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Just for future builders:
I would NEVER suggest using L-wrenches with this kit. Although I have not tried, I would not trust them for even one screw!! The screws are hard enough to get in with a good set of wrenches, let alone a L-wrench.
I've built two kits, and from each one, I still ended up with red lines across my hands from my Dynamite & Losi wrenches.
If you use a tap, I'm guessing you could get away with the L-wrenches, but tapping the holes with the screws themselves, OUCH! I wouldnt even try ( personally )...
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-24-2004, 05:43 PM   #2675
rc-zombies's Avatar
coastaltony..
thanks for the update...that's good to know about the spacers...
Old 03-24-2004, 05:54 PM   #2676
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Tony,
You must have read my building tips....
But, I used a 4mm tap where the droop screws go through the arm, and mine aren't loose.
TSR6,
You should always use a tap! I have Hudy wrenches, and I STILL used a tap!
The way I see it: We're no longer threading screws into soft plastic, like in the TA01 days, all the new stuff is graphite/plastic mixes. Using a tap takes more time, but makes the car much easier to build/take apart.
For Super Steve:
Didn't you read my building tips?!
Hpi Pro 4
RCBuddha is offline   Reply With Quote
Old 03-24-2004, 05:58 PM   #2677
rc-zombies's Avatar
10 more pages 'til we hit the century mark....
Old 03-24-2004, 06:27 PM   #2678
RandyB's Avatar
Just afew snap shot of my pro4 building it slowly for the summer race season
RandyB is offline   Reply With Quote
Old 03-24-2004, 06:34 PM   #2679
RCBuddha's Avatar
Looking good!
Old 03-24-2004, 06:45 PM   #2680
snoopy's Avatar
Finally broke something on my pro4..
Front bevel gears, due to high speed impact into another car parked along the straight......
Rear Ballstud in rear hub...tapping too many boards.
Otherwise car is still going strong after a few months.
snoopy is offline   Reply With Quote
Old 03-24-2004, 07:29 PM   #2681
JusBox's Avatar
LOL, the last page for me on this thread is 67.
JusBox is offline   Reply With Quote
Old 03-24-2004, 08:00 PM   #2682
RCTech Member #2
TSR6's Avatar
Your post bumped it to 68.
Snoopy - Ouch.
Troy
RCTech Member #2
Old 03-24-2004, 08:05 PM   #2683
Hey what is the largest 48P Spur gear which will fit in the Pro4? Im a bit tired of stripping spur gears. Car Drives like a dream its the driver whos bad(me).
Mossie is offline   Reply With Quote
Old 03-24-2004, 08:08 PM   #2684
RandyB's Avatar
just for the heck of it another
Old 03-24-2004, 08:22 PM   #2685
RandyB's Avatar
hey Pro 4 owner i have my brand new one way for sale in the forums section check it out. I will trade for a ball diff
30.00
thanks
