Old 03-24-2004, 12:18 AM   #2641
acutts's Avatar
Looking at pictures of Hara's car I see he runs Delrin diff at the rear of his car. I used to use an Excel Delrin Diff on my SD and liked it. Any idea if HPI will be bringing out a Delrin diff or are there any aftermarket ones that can be bought? Would an SD diff fit?
Any ideas greatly appreciated!
acutts is offline   Reply With Quote
Old 03-24-2004, 05:50 AM   #2642
David Joor's Avatar
R/C Tech Charter Subscriber
The next diff HPI releases will be delrin.
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 03-24-2004, 06:07 AM   #2643
coastaltony's Avatar
David
Any spools out yet?
I just got a spare diff. This one-way has to go for asphalt racing.
Would you suggest locking down the diff, or using epoxy on the one-way?
I may run this car on carpet in the near future.
coastaltony is offline   Reply With Quote
Old 03-24-2004, 06:18 AM   #2644
acutts's Avatar
Thanks for the info David. Any ideas on timeframes for this release ... U know us racers we always want it yesterday ....
Old 03-24-2004, 06:52 AM   #2645
RandyB's Avatar
I would like to see the steel diffs around first. putting down major HP on carpet track can cause some serious stress on the diffs
RandyB is offline   Reply With Quote
Old 03-24-2004, 07:44 AM   #2646
rc-zombies's Avatar
no the SD diff will not fit...already tried it...
Most probably HotBodies or Square will come out with a delrin diff.
I had a delrin diff on my Pro3 and liked it alot.
and to all...
the 1, 1.5 and 2 degree arm mounts was just released from Japan... hopefully we should have it in a month....takes a while for that canoe to paddle to the US...
Old 03-24-2004, 08:19 AM   #2647
RandyB's Avatar
other than weight what are the main advantages for thee delrin diff.
Old 03-24-2004, 08:24 AM   #2648
rc-zombies's Avatar
actually the stock graphite diff is lighter than the delrin...
the delrin diff just runs smoother and more durable.
Old 03-24-2004, 08:26 AM   #2649
RandyB's Avatar
I figured it would be smoother and white parts look trick!
zombies where did you get the titanium input shafts made by square? does square make anything else for the pro4 yet?
Old 03-24-2004, 08:29 AM   #2650
rc-zombies's Avatar
got my Ti input shafts from Rainbowten...and Square makes a ton of option parts for the cars..and I don't they are done yet...
http://www.rc-square.com/
alot of the parts on my car are from Square... except for the transponder mount and servo saver set which are from Jet.
Old 03-24-2004, 08:32 AM   #2651
RandyB's Avatar
Wow I think I want it all! what parts are avail from rainbowten? or what is the web site so i can check it out. And does jet have a we addy?
thanks
Old 03-24-2004, 08:41 AM   #2652
RCGaryK's Avatar
Erik, are you going to be (or already at) the Roar nats this weekend at the Gate?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 03-24-2004, 08:43 AM   #2653
rc-zombies's Avatar
thanks
you'll have to do a search on RainbowTen.
I order some of my parts from RcModel as well...they have most of the Square and Jet parts in stock...
http://shopping.rcmodel.com.hk/
Old 03-24-2004, 09:30 AM   #2654
popsracer's Avatar
Default Pro 4 parts
Guys;
Tower Hobbies has MOST of the essential Pro4 replacement parts in stock now. Still waiting on the Bevel Gears and Arm set though.
popsracer is offline   Reply With Quote
Old 03-24-2004, 09:32 AM   #2655
rc-zombies's Avatar
Default Re: Pro 4 parts
Originally posted by popsracer
Guys;
Had to go overseas to get the bevel gear and arm set...shipping is about the same as Tower....via registered AIR.
