Old 03-22-2004, 04:52 PM   #2611
rc-zombies's Avatar
Originally posted by True R/C Racing
tc3 isnt that bad
yea..I know... I used to own one...many many many moons ago.... it's still a fast car to drive...
Old 03-22-2004, 04:58 PM   #2612
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
For some reason the pro 4 drive smoother thanTC3 and pro4 are easy to dial compare tc3...I give the PRO4 two thumbs up
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 03-22-2004, 05:00 PM   #2613
OSherman's Avatar
Originally posted by David Joor
If going to a shorter link resulted in less rear traction (making the car harder to drive) than lowering the inner link is just going to increase the effect.
actually, lowering the inner camber link position will in turn increase the camber.., possibly a couple degrees... to get back to your original camber setting you will have to make the camber link longer.... also the rate of change in the camber increases, which works in conjunction with your camber setting...
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-22-2004, 05:02 PM   #2614
Send a message via AIM to True R/C Racing
yep, tc3 is a Difficult car to set-up But once you hit that sweetspot of it, it is Real Fast on the track
True R/C Racing is offline   Reply With Quote
Old 03-22-2004, 05:04 PM   #2615
coastaltony's Avatar
RCZ
Could you hit me with the link to that battery tape.
I have ran the Mission since they came out. Not one battery mishap.
Sunday, with the plastic bar, two mishaps with Pro 4.
Need tape.
coastaltony is offline   Reply With Quote
Old 03-22-2004, 05:13 PM   #2616
rc-zombies's Avatar
Originally posted by coastaltony
RCZ
Need tape.
http://www.kthobbies.com/store/motor...ccessories.htm
Team1 strapping tape...but KT is out of stock..
Speedtech does have something similar.
Old 03-22-2004, 05:39 PM   #2617
David Joor's Avatar
R/C Tech Charter Subscriber
What does the actually mean? This is what I just said without explaining it.
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 03-22-2004, 05:49 PM   #2618
Thanks to all you fellows. Quite good information.
I ordered a few sets from TH.
I'll see what happens in practice this week.
Old 03-22-2004, 06:04 PM   #2619
OSherman's Avatar
the issue was the fact that he had to go to a shorter camber link... a lower inner position will give a lower roll center point and longer link.. the rate of change in camber will increase so you may or may not need as much camber...
•KO Propo America
•EXOTEK
Old 03-22-2004, 06:05 PM   #2620
David Joor's Avatar
Originally posted by protc3
ok guys,here is the complete kit.the picture quality kinda sucks its kinda dark i guess.let me know what ya think
Look at that beauty, can't wait to get my hands on one.
Old 03-22-2004, 06:20 PM   #2621
Super Steve's Avatar
Send a message via AIM to Super Steve
Is that the final production version?
Super Steve is offline   Reply With Quote
Old 03-22-2004, 06:23 PM   #2622
RCGaryK's Avatar
I've heard of one arm breaking, but I won't mention RCDriverGary's name on here.
Yeah, I hit that pipe a ton, going full-tilt-boogie. I wasn't as suprised that I broke the right front arm as I was that the left rear ball stud broke, and I have no idea how that happened. But what suprised me the most was the fact that the hit that broke the arm...didn't take a ring and pinion gear with it!
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 03-22-2004, 06:25 PM   #2623
Send a message via ICQ to Cobra81li200
the issue was the fact that he had to go to a shorter camber link... a lower inner position will give a lower cg point and longer link.. the rate of change in camber will increase so you may or may not need as much camber...
Hum, I assume you mean a lower roll center. It's unlikely that changing the position of the camber links changes the position of the centre of gravity...
Cobra81li200 is offline   Reply With Quote
Old 03-22-2004, 06:28 PM   #2624
OSherman's Avatar
oops, true..
•KO Propo America
•EXOTEK
Old 03-22-2004, 07:16 PM   #2625
purplepro3's Avatar
Guys...it has been a while since I posted here (actually it has been a year since I touched an r/c). Just want to know if there is any difference between the Pro4 released in Asia and the one here in the US.
purplepro3 is offline   Reply With Quote
SEO by vBSEO 3.5.0
