Like Tree5Likes
Old 03-20-2004, 09:02 PM   #2566
forty6's Avatar
Originally posted by TSR6
Uhhhhh - Got Balance?
Golf tees....very ingenius...dime a dozen compared to the expensive Hudy version.
p.s.
A few more grams to the right...LOL..j/k
forty6 is offline   Reply With Quote
Old 03-20-2004, 09:05 PM   #2567
forty6's Avatar
Originally posted by Super Steve
I dunno man, yours is tilting...
http://www.rctech.net/forum/attachme...&postid=676809
rc-zombie's look really balanced (but for all we know, he could be cheating )
Well, we can't see rc-zombies' front axles. Because he was holding it for the camera. Just kidding rc-z.
Old 03-20-2004, 09:07 PM   #2568
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
LOL, it's actually just a touch electronics side heavy in the pics, but when it stops teetering, its just about there. I need to cut just a sliver off one of the weights instead of tossing on a whole 1/4oz ( causing the slight tilt. )
I don't think I'm going to run it with the extra weight. It's a touch overweight as is. Too bad GP cells are so heavy, If I were still running HV cells, I would bet the car would almost be at roar minimums as is. I don't have a scale here, so I'm just guessing off of how much I had to add for the USTC ( had to add 1.75oz to get the car RIGHT on Roar min. I thought I was going to have to run a spare body clip, but once the scale settled...heh... it was good )
I took a better pic:
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-20-2004, 09:21 PM   #2569
Super Steve's Avatar
Send a message via AIM to Super Steve
hmmm...
Now with body and fake transponder.... j/k
Super Steve is offline   Reply With Quote
Old 03-20-2004, 09:24 PM   #2570
RCTech Member #2
TSR6's Avatar
hmmm...
I run a Personal Transponder, It's mounted in the center of the chassis, via the two steering post screws.
http://www.rctech.net/forum/attachme...?postid=731288
Troy
RCTech Member #2
Old 03-20-2004, 09:28 PM   #2571
Default Chassis Tweak Issue Fixed (maybe)
I think I have found a fix for the chassis tweak issue that happens with every bump. My testing has shown good results, but I thought I should see what you guys think and let you test it. Looks like I will be implementing it on all of our chassis kits (doubt if I will still do a Pro4, though).
I put a heli-coil (small threaded insert) into the upper deck graphite part. This prevents any play that can exist in the screw hole. HPI counter sunk the holes to try and get the same effect, but it does not seem to be working. This also means that you will need to get a new upper deck that is not counter sunk from any one of the many designers that are coming out with a chassis kit for the pro4, and use button head screws instead of the original flat head screws. Just make sure you get one of very good quality, as a misaligned hole will cause the chassis to become tweaked.
I hoped I adequately explained this modification. Let me know how it worked for you.
Thank You,
Louis
BallisticHobbie is offline   Reply With Quote
Old 03-20-2004, 09:47 PM   #2572
RCBuddha's Avatar
Trader Rating: 33 (100%+)
What is ROAR's minimum weight requirement? In other words: what is the minimum weight our cars have to meet?
RCBuddha is offline   Reply With Quote
Old 03-20-2004, 10:04 PM   #2573
RCTech Member #2
TSR6's Avatar
EDIT - 50 oz for foams and rubber 53 oz. - can someone confirm this for me? It sounds right, but I did not pull this from the rule book.
I just know I had to add 1.75oz to make rubber tire weight at the USTC, and don't remember what measurment the scale used ( wasnt oz, but it had the number we needed written on it )
It took 2.25 to balance it, so it's .5oz overweight when balanced. The car really isnt setup as light as it could be though. Tape is doubled up on the batts, my heaviest pack, along with wires that can be shortened and I have a battery brace on the side.
To make a long story short, I'm home on spring break, there was a birthday party for my little brother tonight at my house. The whole family was here, including 5 of my little cousins, all under age 10 running around and screaming. Curious mind while being bored, hidden in my room for a little "quiet time"
Troy
RCTech Member #2
Old 03-20-2004, 10:33 PM   #2574
rc-zombies's Avatar
no electornics was installed yet... my post was to inform everyone that the xray balancing tool will work with the car... a tool left over after selling the EVO2.
Old 03-20-2004, 11:12 PM   #2575
tc3 racer sc's Avatar
hey i see the ccx post under ur car i drive for cse in charlotte and race too just got my pro4 still keeping the tc3
tc3 racer sc is offline   Reply With Quote
Old 03-21-2004, 06:23 AM   #2576
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Default pucho
hey its build and ready the sand paper u gave me to get worked.drive tran is very free.thanks for the spring set up i will do that when i go over there.when is rpm racing again? i will be racing at ft raceway on 28/03 thats going to be my first race thanks
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 03-21-2004, 12:23 PM   #2577
Send a message via AIM to True R/C Racing
Default Re: pucho
they race thursday. Cmon hit the carpet, asphalt=no good
True R/C Racing is offline   Reply With Quote
Old 03-21-2004, 12:58 PM   #2578
Super Moderator
Tony Rivas's Avatar
Default Re: Re: pucho
sorry but i like to race eveywhere
Old 03-21-2004, 05:06 PM   #2579
RandyB's Avatar
pucho which hara set up are you refering to? you are running on asphault right? Just asking cause i think if I remeber correctly our set ups were close to the same when we were bith running xrays
good thing i kept my 80 dollars worth of xray springs
RandyB is offline   Reply With Quote
Old 03-21-2004, 06:40 PM   #2580
Wow...
80 dollors worth of springs...
how many springs is that?
