Old 03-17-2004, 01:07 PM   #2461
chr15tophe's Avatar
in the instructions it definetly shows to use a nut as appossed to a locking nut and in the begining of the instructions where it lists parts (page 6) to use, it just says m2 nut, below they refer to an m3 locking nut, theres a clear distinction between nuts, bizarre...
chr15tophe is offline   Reply With Quote
Old 03-17-2004, 01:12 PM   #2462
coastaltony's Avatar
DITTO!
coastaltony is offline   Reply With Quote
Old 03-17-2004, 01:12 PM   #2463
rc-zombies's Avatar
On both the US and Japan manuals...page 14..the illustration shows a nylon lock nut...
if that's the case apply some of the MIP thread lock on it...and it will stay put...
Old 03-17-2004, 01:31 PM   #2464
chr15tophe's Avatar
trust us british to be different heheheh
Old 03-17-2004, 01:54 PM   #2465
OSherman's Avatar
lol
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-17-2004, 02:12 PM   #2466
black-knight's Avatar
R/C Tech Charter Subscriber
Default Re: diffs again sorry
Ok ive been suffereing from diffs loosing ever since ive got this car, tonight i cracked it, the problem being the nut that goes on the thrust screw is only a nut not a nylon lock nut, which can be found in tc3 and yokomo cars, am surprised no one else has this problem because a normal nut will come loose, will now have to find such a lock nut or use 2 nuts per diff.
Will send a note to Harry hara !!
I put my diff nut on backwards and use a little thread lock. I have had no issues since doing this. Was a real pain at first!!!
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 03-17-2004, 05:40 PM   #2467
popsracer's Avatar
Default Hpi Pro 4
Guys;
Found a little time to start working on the Car today.
The Countersinking on the bottom side of the Chassis is definitely too shallow for the screw heads.
Having a Drill press and proper countersink bit, I made all of them a little deeper until the heads were flush with the bottom of the Chassis. Not sure why this wasn't done at the factory.
popsracer is offline   Reply With Quote
Old 03-17-2004, 07:03 PM   #2468
rod_b's Avatar
Send a message via AIM to rod_b
Does anyone use tape on their chassis to protect it from scrapes? What kind is it and where can I get some? Thanks
rod_b is offline   Reply With Quote
Old 03-17-2004, 07:07 PM   #2469
Send a message via AIM to True R/C Racing
its a Chassis Protector. yes its very good, helps chassis stay in good condition. YOu can get from LHS its like $12 (not sure)
True R/C Racing is offline   Reply With Quote
Old 03-17-2004, 07:13 PM   #2470
popsracer's Avatar
Associated Chassis Protector Tape.
Been several years since I've bought some, but any well stocked shop should carry it.
Rod, See you at the track.
Old 03-17-2004, 07:59 PM   #2471
forty6's Avatar
Default Re: Hpi Pro 4
Originally posted by popsracer
Guys;
Is this a widespread problem? I know someone brought it up a while back when the car was first released. Was it just a bad batch early in the production cycle? Thanks.
forty6 is offline   Reply With Quote
Old 03-17-2004, 08:02 PM   #2472
forty6's Avatar
Here was the post back in January (page 33 of this thread).
Originally posted by Kenneth Tan
Anyone noticed that the screws are protruding from the bottom of the main chassis, i.e. the countersunk holes are not deep enough? Thanks.
Old 03-17-2004, 09:52 PM   #2473
OSherman's Avatar
interchangable parts?...
just got done assembling my CVDs... dropped one set screw, so i decide to go to my old pro3 stash... found a set screw... while there in stash, compared the PRO3 axle to the PRO4 axle... appears to be the same...
Eric, Thad, Frank?... is this really so??... would be good to know some of 'us' alredy have spares...
•KO Propo America
•EXOTEK
Old 03-18-2004, 01:33 AM   #2474
Frank McKinney's Avatar
I think the bearing sizes are the same in the hubs from Pro 3 to Pro 4, I'm not sure about the axle length, but I think the TC pivot circular thingies are the same on all the MIP CVDs but I can't be sure. I don't want to say yeah they fit because I'll be in trouble if they don't.
The surest test (apart from Erik saying yeah they fit) is - do they fit?
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 03-18-2004, 04:06 AM   #2475
Frank,
Thanks for your very detailed and informative reply.
RC Donkey is offline   Reply With Quote
