Like Tree6Likes
Old 03-17-2004, 10:04 AM   #2446
snoopy's Avatar
I bought the alloy front hubs as a backup since my tc3 used to have a problem with these striping out.....However the Pro4 seems to be alot stronger and has'nt had this problem, so stick to the plastic ones.
Could'nt be happier with my pro4........well done Eric..
snoopy is offline   Reply With Quote
Old 03-17-2004, 10:12 AM   #2447
coastaltony's Avatar
For you racers running on smooth asphalt, what shock oil weights are working the best? Also what spring ft/lbs?
coastaltony is offline   Reply With Quote
Old 03-17-2004, 10:13 AM   #2448
rc-zombies's Avatar
Oil: 40F / 30R... stock springs and set-up seems to work in most cases...
Old 03-17-2004, 10:18 AM   #2449
Thanks man!
Hope the weather holds out.
Will run it tonight.
Old 03-17-2004, 11:03 AM   #2450
RCBuddha's Avatar
Trader Rating: 35 (100%+)
tony, I've had good success with #3 piston/50wt all around. I've been using the stock springs, but you can try ae blue springs in front and silver in rear. Or if the track has a lot of traction, try AE Red in front and Blue in rear.
RCBuddha is offline   Reply With Quote
Old 03-17-2004, 11:44 AM   #2451
RandyB's Avatar
Cant wait for the wheather to break so I can rolll this bad boy on some tarmac
RandyB is offline   Reply With Quote
Old 03-17-2004, 11:53 AM   #2452
OSherman's Avatar
Thumbs up Re: Re: Hpi Pro 4
Originally posted by RCBuddha
...I think you'll like the way it builds, and how it runs on the track.
Buddha
Yup!!.. just started building mine... and it pieces together like a puzzle... very nice!! can't wait to get it on the track...
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-17-2004, 12:50 PM   #2453
Cool, I just about gave a kid at the track all my TC3 springs.
I was planning on the maiden voyage this afternoon. Then the brown Santa shows up with the aluminum input shafts. Back to the bench.
Old 03-17-2004, 01:17 PM   #2454
First snag!
The Tobee aluminum input shafts have 4 washers/spacers in the pack. Do I need them?
Old 03-17-2004, 01:27 PM   #2455
rc-zombies's Avatar
First snag!
I got the Square Ti input shafts...and it was a direct replacement no spacers needed... Tobee spacers the same as the HPI spacers?
Old 03-17-2004, 01:40 PM   #2456
I sure like the ease of ripping the
diff's apart. Not like my Mission
Carbons.
HPI uses 3 x Z877, and 3 X Z852.
3 x Z877 = .63 mm
1 x Tobee = .52 mm
Old 03-17-2004, 01:43 PM   #2457
rc-zombies's Avatar
Carbons.
3 x Z877 = .63 mm
1 x Tobee = .52 mm
yea the diffs are a pain to get to...but can't complain too much..the car is awesome..
don't know about those tobee spacers... if the Tobee shafts are the same as stock...you may not need them and use the stock spacers...
Old 03-17-2004, 01:49 PM   #2458
Rear shaft appears to be direct fit.
I will use HPI spacers, as in stock set-up.
Old 03-17-2004, 02:01 PM   #2459
chr15tophe's Avatar
Default diffs again sorry
Ok ive been suffereing from diffs loosing ever since ive got this car, tonight i cracked it, the problem being the nut that goes on the thrust screw is only a nut not a nylon lock nut, which can be found in tc3 and yokomo cars, am surprised no one else has this problem because a normal nut will come loose, will now have to find such a lock nut or use 2 nuts per diff.
Will send a note to Harry hara !!
chr15tophe is offline   Reply With Quote
Old 03-17-2004, 02:03 PM   #2460
rc-zombies's Avatar
Default Re: diffs again sorry
that's odd mine came with the nylon lock nut.
