Old 03-10-2004, 06:30 AM   #2161
coastaltony's Avatar
I just opened my box.
What is the concensus on cooking the parts?
coastaltony is offline   Reply With Quote
Old 03-10-2004, 06:39 AM   #2162
Oasis's Avatar
Trader Rating: 36 (100%+)
TSR6 when you change to wider hex's let me know how it works out,I'm running yokomo rims and they have a shallow hex,another problem I have had is the rear rims rubbing on the bottom shock mount and the top camber ballcup.With the kit setup it's a very tight fit(and yes I'm using the right washers )anyone else notice this.
Oasis is offline   Reply With Quote
Old 03-10-2004, 06:46 AM   #2163
David Joor's Avatar
R/C Tech Charter Subscriber
Personally, I feel the trackwidth options are essential to the setup of all HPI vehicles. I would only get the wider hexs if you are always running full width or unless you are actually spinning the wheels but I wasn't in mod foam carpet and that is the best test for durability.
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 03-10-2004, 07:30 AM   #2164
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
David - The wheels our track is using as a spec tire ( CS27 preglues on Speedmind rims ) have a pretty shallow hex.
If i need to adjust width, I can always go back to the stock hexes.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-10-2004, 07:38 AM   #2165
David Joor's Avatar
Oh, that would make sense than, oddly enough I didn't know there were wheels more shallow than others. Is that just the speedline wheel or typical for rubber wheels all together compared to foams?
Old 03-10-2004, 07:45 AM   #2166
RCTech Member #2
TSR6's Avatar
All the foam tires I have are pretty deep for the hex. The tires I have now are fine too, the one wheel I spun the hex on was the same tire I was running when I broke my gear ( hehe ) weeks ago. It was damaged from that, and finally ended up spinning tuesday.
I have noticed that Proline, HPI, and a few others generally have deeper hexes. Yokomo and speedmind are pretty shallow.
xxxkat - shave the top ballcup with an xacto.
Troy
RCTech Member #2
Old 03-10-2004, 07:58 AM   #2167
David Joor's Avatar
Hmm, I just got a killer idea for adjustable trackwidth that you can use on narrow wheels. I was going to spill it but I think I may design it instead because it is a good idea. Just let me know if it is a common problem everyone and I will send the idea to Racer's Edge or HPI.
Old 03-10-2004, 08:16 AM   #2168
V12
V12's Avatar
Originally posted by rc-zombies
It's 2am overthere...and you're still up... cramming for exams?
the wider hex is #72036..... "Buy HPI" had some for sale...but sold out... You can also get the Altas version from Integy...you'll need the 6.3mm +/-
Tamiya also have some 6mm wide hex. Itīs # 53569 and itīs the clamping type. As axle diameter is the same as PRO4 it should work. Package contains 4 pcs including all hardware and should be in the 15-20 $ range.
V12 is offline   Reply With Quote
Old 03-10-2004, 08:58 AM   #2169
rc-zombies's Avatar
are they Purple?
Here's the Atlas hubs...
http://integy.automated-shops.com/cg...53104570052.f3
Old 03-10-2004, 09:47 AM   #2170
V12
V12's Avatar
are they Purple?
No they are Silver.
Old 03-10-2004, 02:09 PM   #2171
Super Steve's Avatar
Send a message via AIM to Super Steve
hi... where is the cheapest onlin eplace were you can buy a pro 4 and they have good service to canadians...
Super Steve is offline   Reply With Quote
Old 03-10-2004, 02:11 PM   #2172
rc-zombies's Avatar
Speedtech...
Old 03-10-2004, 02:16 PM   #2173
Devil_Yellow's Avatar
The hexes are inside the rims who cares what color they are....
NE1 having trouble with tweak... my car constantly wants to tweak the chassis without a hit just seems to want to be in that position... have loosened the shocks, topdeck and reset but it just wants to go back after a couple of races.
I also have a problem with the car being extremely loud. I have checked diff backlash and all is sweet and it rolls expremely well just on the track it makes a shreeking noise like some of the corallys start to when the get old... I have 3 pro4's - one for concrete and one for ashphalt one for parts - so im think im gonna parts this one and use one of the others...
Devil_Yellow is offline   Reply With Quote
Old 03-10-2004, 02:18 PM   #2174
rc-zombies's Avatar
If you're a true HPI fan...it's got to be purple...
Old 03-10-2004, 02:20 PM   #2175
JusBox's Avatar
That would drive me nuts!!!! Not acceptable...
JusBox is offline   Reply With Quote
