Like Tree6Likes
Old 03-01-2004, 10:01 AM   #1951
rc-zombies's Avatar
Default Re: diff slippage
Originally posted by chr15tophe
infact looking at the manual closer, the drawing shows 5 thrust balls in the diagram to build it, the part number shows x6 on the left hand side of the page and beside the pic of the thrust race it shows 6 balls with part number A150..
How many have people used in theres then??
6 balls installed...
Old 03-01-2004, 10:03 AM   #1952
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
The US manual shows 6 in the picture, and x6 on the side.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-01-2004, 10:07 AM   #1953
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Did you CA the the inside ring on the diff gear? Perhaps that could be the problem.
RCBuddha is offline   Reply With Quote
Old 03-01-2004, 10:16 AM   #1954
Downforce is offline   Reply With Quote
Old 03-01-2004, 10:18 AM   #1955
chr15tophe's Avatar
yep glued the ring in, might have possibly come unstuck will check, i have 6 thrust balls also
chr15tophe is offline   Reply With Quote
Old 03-01-2004, 12:04 PM   #1956
The Teacher's Avatar
Trader Rating: 48 (100%+)
My kit is a US kit and it shows 5 balls in the assembly...
The Teacher is offline   Reply With Quote
Old 03-01-2004, 12:07 PM   #1957
rc-zombies's Avatar
That is odd...typically with other cars it's six... I think it's a typo.
Old 03-01-2004, 04:16 PM   #1958
racer's Avatar
i also found typos in the ball diff instructions.
the part #A157 2.4mm balls should be used inside the ball differential.
while, #A150 2mm balls should be used with the diff screw
racer is offline   Reply With Quote
Old 03-01-2004, 04:25 PM   #1959
racer's Avatar
scan of instructions
Old 03-01-2004, 04:27 PM   #1960
rc-zombies's Avatar
you should send it direct to HPI...
They were suppose to fix all the typos with the updated manual...
Old 03-01-2004, 06:33 PM   #1961
Default freeing up the pro 4 drive train
I just got my pro 4 built and noticed the heavy steal input shafts used.. Has anyone tried any thing to free up the drive train? Has anyone been able to get parts yet?
pablo1 is offline   Reply With Quote
Old 03-01-2004, 06:36 PM   #1962
the drivetain is pretty much free as is I did put white lighting on the gears and that seemed to help the car run quieter and free Ran the car for the first time sat and sun had some speedo problems but once I fixed that the car was pretty good.
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Old 03-01-2004, 07:42 PM   #1963
TeamPRP's Avatar
The PRO 4 drive train should be very free straight out of the box. If it isn't check to make sure none of the shims are bent. Especially the 3 large shims in the rear gear box. The only adjustment I made to mine while building the car was in the front gear box. Instead of 2 shims on one side of the one way diff, I used a single shim on each side. And I applied a very light coating of the included white cap "diff" grease on the gears as stated in the manual. My car spins very free and it runs very quiet. Even though I took a few decent sized hits, I did not break any parts while racing it this past weekend at the Winterfest race at Trackside.
TeamPRP is offline   Reply With Quote
Old 03-01-2004, 07:51 PM   #1964
snoopy's Avatar
I used 6 thrust balls.
No problems with the diffs in any form, running brushless.
Have added 1 extra large shim to rear g/box
snoopy is offline   Reply With Quote
Old 03-01-2004, 10:25 PM   #1965
Oasis's Avatar
Trader Rating: 36 (100%+)
Bigdog,Matt was slaming your Pro 4.. Told all it was not a good outting for the Pro 4..whats up..
Oasis is offline   Reply With Quote
