Like Tree6Likes
Old 02-29-2004, 05:02 PM   #1936
rraden's Avatar
Trader Rating: 231 (100%+)
Downforce
Did you run 19T or stock? What was your TQ laps and time?
My Pro 4 is almost done so it should be ready for initiation by this Friday!
rraden is offline   Reply With Quote
Old 02-29-2004, 05:19 PM   #1937
rc-zombies's Avatar
Originally posted by RBLove
Question:
I have a question about the boiling gears in water dealio. How long are you doing this for? Are you doing it on any other plastic parts on the car? I do not run a Pro 4, but am interested in trying something on my current car. Thanks.
so far just the beveled gears... have no problem with durability of the other graphite parts yet..like the arms...
after the water has boiled...turn it off and let the parts soak for about 20-30 min. after that just towel dry them and apply you favorite lube. I use the Paragon Ultralon, Whitelightning bike grease works well too....
Old 02-29-2004, 05:36 PM   #1938
Originally posted by rraden
Downforce
Stock. 30\5:00.1 Had a good 3-4 seconds lost due to traffic. Fastest TQ was 30\5:09. I also ran a diff up front. Worked better on the tight track.
Downforce is offline   Reply With Quote
Old 02-29-2004, 08:39 PM   #1939
Oasis's Avatar
Trader Rating: 36 (100%+)
Drove/raced my Pro 4 for the first time today,all I can say is wow this car is fast and hooked up,Ran really good today,best lap times for me ever at this track,but in the main I got punted(and I mean PUNTED !!) fought my way back to 2nd but the leader had checked out,but the bummer is I broke the ring and pinion gear on the front(chiped teeth).. I did finish the race..with a clicking noise,So mid march before we start seeing parts in our local hobby shops.. Dang..back to the R2 for a few weeks..
Oasis is offline   Reply With Quote
Old 03-01-2004, 12:27 AM   #1940
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
xxxkat - when my lhs talked to horizon last friday, it sounded like the gears should be in around march 15.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-01-2004, 03:08 AM   #1941
Have anyone found out a good way to shims the gears on the pro4. Just ripped mine this weekend In the manual it says 2 shims on the one way, I did this with the boiling prosess but ripped it...
sturla is offline   Reply With Quote
Old 03-01-2004, 04:27 AM   #1942
The Teacher's Avatar
Trader Rating: 48 (100%+)
sturla, I think with the one way there is no way around stripping gears when you take a hard hit. If the wheels are locked so they can't move but the motor is still turning something has to give. (in most cases the one way gear. With a diff the gear can slip. This has been a problem with almost all gas and elec cars. I shimmed my car per the instructions and didn't boil the gears and my gears are fine. If you can try the diff in the front you will not have this problem...
The Teacher is offline   Reply With Quote
Old 03-01-2004, 09:21 AM   #1943
chr15tophe's Avatar
Default Weekends racing
My pro4 also did really well 1st ttime driving on carpet up against some stiff competition that were faster than me, qualified 6th finished 3rd, didnt break a thing, used a diff as v tight circuit, apply grease to the diff gears, the diff matereial will absorb some of the misture in the grease.
Any ones diffs coming loose??? ive ran mine for 2 meets now and they seem to be working a little loose too often..?
chr15tophe is offline   Reply With Quote
Old 03-01-2004, 09:22 AM   #1944
Is the Integy Weight Distribution Gauge decent? a rip off? Can one just make do with ordinary kitchen scales?
jleibund is offline   Reply With Quote
Old 03-01-2004, 09:26 AM   #1945
rc-zombies's Avatar
I don't think it's all that great...you're better off getting a couple of postal scales...about $20.00 at Costco...if they still sell them..
Old 03-01-2004, 09:41 AM   #1946
popsracer's Avatar
Default Still going strong
Guys;
Wanted to say that I did pretty well in Stock Sedan with my Pro-3 this weekend.
Out of a field of 38 entires, qualified 3rd overall and finished 4th (got out motored). Was my first time running the Car since Nov 03.
With everyone posting much faster lap times than before running a Pro-4. I can't wait for the parts support to come in and I will be buying mine.
popsracer is offline   Reply With Quote
Old 03-01-2004, 09:45 AM   #1947
rc-zombies's Avatar
Default Re: Still going strong
Originally posted by popsracer
Guys;
Still racing that Pro3? sometime I wish I still had my Hara edition... I had very good runs with that car than any other... Now the Pro4 is even better... Hope you get one soon....
Old 03-01-2004, 09:48 AM   #1948
chr15tophe, I had a problem not being able to tighten my diff tight enough to stop slipping. It turned out to be my fault, I put too many thrust balls in the diff assembly. I think I used 7 instead of 5 as per the instructions. It could possible be this. If not that check the M2 nut used to tighten the diff could possibly be bad...
Old 03-01-2004, 09:56 AM   #1949
chr15tophe's Avatar
Default slipping diff
Im in the UK my manual says to put 6 thrust balls in. will check the amount when i strip them down.
Old 03-01-2004, 09:59 AM   #1950
chr15tophe's Avatar
Default diff slippage
infact looking at the manual closer, the drawing shows 5 thrust balls in the diagram to build it, the part number shows x6 on the left hand side of the page and beside the pic of the thrust race it shows 6 balls with part number A150..
How many have people used in theres then??
