Like Tree5Likes
Old 02-27-2004, 03:27 PM   #1891
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Originally posted by TSR6
Working on the Pro4 is pretty easy once the screw holes get worked in a little bit. The first couple times of removing the upper deck can be a chore thanks to the stiff composites. Now that I've put the screws in and out several times, It's not so bad.
I'm surprised that many of you are not pre-threading or "tapping" your parts with a 3mm tap! I know it takes a lot longer to build the car, but man, it made it a heck of alot easier to build for me!
If you decide to use a tap handle and tap, most of the screws are 3mm, but make sure to use a 4mm tap for the droop screws. Also, be sure to use a little of the dark grey grease when tapping the parts, this will help keep it cool.
Another tip: Use some chapstick on the turnbuckle threads; it'll make it easier to thread them into the cups.
RCBuddha is offline   Reply With Quote
Old 02-27-2004, 03:54 PM   #1892
rc-zombies's Avatar
I used a power screwdrive with a 2mm hex bit.... hand tighten when it gets to the screw head... this is easier on your hands and wrist.
Old 02-27-2004, 03:58 PM   #1893
RCBuddha's Avatar
Or you could do that....
Old 02-27-2004, 04:00 PM   #1894
rc-zombies's Avatar
Faster...you only do it once...and like RCBuddha said...make sure you grease your threads aswell...
Old 02-27-2004, 04:07 PM   #1895
Trinity2's Avatar
Unhappy
Oh man!!! Thanks to you buddha and zombie. After that all pain in my hands you told that how to make it easier, after those many tight scruws...
3x Auts
I`m almoust finished my Pro4
No pain no game
Trinity2 is offline   Reply With Quote
Old 02-27-2004, 08:34 PM   #1896
Russ-ygm.
Downforce is offline   Reply With Quote
Old 02-27-2004, 08:36 PM   #1897
JusBox's Avatar
3x Auts
No pain no game
no, no pain no gain!
JusBox is offline   Reply With Quote
Old 02-27-2004, 08:38 PM   #1898
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Thats the way I see it, no pain, no gain.
I've always been against power drills, just because it makes it so much easier to strip a screw's threads or the screw head. I guess it's fine if you've built cars like that before, and if you take your time, but it never something I would suggest to a new guy.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-27-2004, 08:44 PM   #1899
rc-zombies's Avatar
with the graphite parts...the chance of stripping the threads is less compared to the usual plastic parts... I use a variable speed driver at it's slowest speed.... and next to the lowest torque setting... with normal plastics parts..it's all elbow grease...
Old 02-27-2004, 08:54 PM   #1900
RCTech Member #2
TSR6's Avatar
Yeah, I'm just saying it's not something I generally recommend.
I used to use one on my Pro2 & RS4 Racer2 without any problems, but I wouldn't tell someone here, or walking out of the hobbyshop to use one unless they know exactly what they are doing, which I'm sure you did.
From my time working in a hobby shop, I've seen quite a few kids using dad's electric screwdriver and stripping the heads, the threads, or the plastic.
Troy
RCTech Member #2
Old 02-28-2004, 01:04 AM   #1901
RCBuddha's Avatar
That's why I recommend using a tap handle and thread tap. You could even get a ratcheting tap handle, which I've used in the past with good results.
Old 02-28-2004, 02:11 AM   #1902
Trinity2's Avatar
Post
Tower has lowered price for Pro4, now it`s 330$. It`s still expensive compare Speedtech
Spareparts are available mid mar
BUT, where i can get extra spurgears, bevelgears and pivot blocks like 2.0 and 2.5*???
Old 02-28-2004, 02:17 AM   #1903
snoopy's Avatar
Some shops in asia have spare parts, but have'nt been able to find the 2.0 pivot blocks anywhere yet...
snoopy is offline   Reply With Quote
Old 02-28-2004, 03:50 AM   #1904
Ronald B's Avatar
Default hpi springs
i run it for the fist time and the car performs very well
out of the box only few changes where made
does anybody now the lbs of the hpi springs
i run hpi for the first time , but was impressed about quality
of the kit was nice to built it
Ronald B is offline   Reply With Quote
Old 02-28-2004, 06:44 AM   #1905
yobbism's Avatar
Heya got mypro4 today the other day!
Built it. Very different to the other cars from HPI..........
gave me a bit of a shock..........with shims and the like.....lol........
But very nice. Took a while to ge thte drivetrain nice and smooth and free but its all good. very nice car. i like the change to all the hops ups included!!!
a week until i can track test it though but it will be worth it.
yobbism is offline   Reply With Quote
