Hpi Pro 4
#1863
it looks mroe like a novak brushless to me and not a gt7
#1868
Originally posted by xxxkat
Well the field is down to 4,I should know by next week,I would have to say,the pro 4 the cuda..just not sure after that,heck I might even have a mI2 or 415 by then..
#1869
jleibund,
I'd say your missing your arm mount spacers or your arm mounts are mounted wrong.
#1870
oneway with foam on carpet
Why doesn`t anyone use onway on carpet? Seems to me that I must use a oneway this weekend because I don`t get the diff in time
#1871
You know Sturla, the Americans are, in Norwegian "Skikkelige pingler som ikke kan kjøre modellbil"
#1872
Re: oneway with foam on carpet
So far the pro4 has been better than any other car i have tried with oneway on our track. i will keep working on setup using oneway before switching to 4wd. I got a spare diff already to try out.
#1873
Sturla,
When running on foam tires the grip is simply too much to use a one-way. Running a standard diff makes the cars more forgiving and more predictable....
With rubber tires a one-way is usually faster....
Cheers,
Eirik
Cheers,
Eirik
#1874
Spring Perches
#1875
Agreed, On carpet with rubber tires, one way diffs are usually faster, even on tighter tracks - assuming the one-way works with the person's driving style. For some people it may take a while to get used to, but I love driving one-way cars.
jleibund - I knew Erik would come on here with a quick and easy solution.
