Old 02-25-2004, 04:34 PM   #1846
RCBuddha's Avatar
Trader Rating: 33 (100%+)
My concern is the fact that his shock collars are at the top of the shocks, and his rideheight is still high. Something doesn't seem right...
Buddha
RCBuddha is offline   Reply With Quote
Old 02-25-2004, 04:37 PM   #1847
rc-zombies's Avatar
Buddha
I agree something is messed up some where...on mine with the same set-up...if I put the shock collars all the way to the top...it's about 4 to 4.5mm height.
jleibund... what is the shock length?
Old 02-25-2004, 04:38 PM   #1848
Talking
Well, I have a pair of 24mm racing slicks:
http://www2.towerhobbies.com/cgi-bin...?&I=LXSE80&P=7
They seem to be approximately the same diameter as the X-patterns - Tower lists most of them as 66mm, including those Advan A038 that someone recommended. Does anyone have a link to tires listed at 60mm outer diameter.
Also, thanks for the droop comments, please pardon my 'green-ness' with all of this, eventually I'll get it through my thick skull
jleibund is offline   Reply With Quote
Old 02-25-2004, 04:39 PM   #1849
The overall length from end of plastic eyelet to end of plastic eyelet is 62mm
Old 02-25-2004, 04:42 PM   #1850
Just got my Pro4 yesterday what do you use to prep the chasis whith ca glue do you brush it on .
sportracer is offline   Reply With Quote
Old 02-25-2004, 04:44 PM   #1851
rc-zombies's Avatar
Unmounted shock fully extended should be 67.5mm in length.
Old 02-25-2004, 04:44 PM   #1852
RCBuddha's Avatar
I used an old nail file to sand the edges (use the fine grit side). Then soak a q-tip in thin CA and carefully apply to the edge of the chassis. When dry, it should look shiney.
Buddha
Old 02-25-2004, 04:45 PM   #1853
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I used my finger, and pealed the glue off afterwards.
I started out using one of the parts bag to push the glue around, but found the finger method to be faster.
For inside the battery holes, I used a thing called a "Microbrush" http://www.microbrush.com/
I also use the Microbrushes to clean my airbrush after use. They are handy to have around, and dirt cheap.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-25-2004, 04:50 PM   #1854
I pulled the shock off the chassis - my adjusted measurement is 64.5mm
Old 02-25-2004, 04:50 PM   #1855
rc-zombies's Avatar
I use med CA so it doesn't run and just slide the tip all around the chassis.... then spray it with Accelerator... BAM!
haven't tried the finger method...hmmm maybe next time..
Old 02-25-2004, 04:52 PM   #1856
Sorry for all the posts - zombie that is with the collar all the way at the top. With the collar about 1/2 way down I also get 67.5
Old 02-25-2004, 04:52 PM   #1857
rc-zombies's Avatar
hmmm.....
send your car to me...and I'll figure it out...
Old 02-25-2004, 04:53 PM   #1858
rc-zombies's Avatar
Full extension...67.5mm
the shocks shafts all the way out....
Old 02-25-2004, 04:54 PM   #1859
RCTech Member #2
TSR6's Avatar
You have to move quickly, and keep your finger wet, otherwise...well, you start to see how quickly the glue sets.
jei - I wish I had my car here to measure for you.
Troy
RCTech Member #2
Old 02-25-2004, 05:08 PM   #1860
zombie - I got 67.5mm with them all the way out too. Maybe I should send it to you!
