Old 02-25-2004, 04:51 PM   #1816
rc-zombies's Avatar
Originally posted by jleibund
Yeah, I'm using the same purple HPI option parts you are. They have about the same amount of space as the factory black ones... I measured them.
the black one the springs sit lower...thus the shock adjusting nut is lower on the shock body...
I have what you have and no problems with 4.5 - 5mm ride heights. even with the shock collars all the way to the top...you'll still be able to get 5mm ride height.
Old 02-25-2004, 04:52 PM   #1817
rc-zombies's Avatar
take a pic of the front without the front bumper in place...
Old 02-25-2004, 04:53 PM   #1818
Those X-pattern tires are larger than normal. Also drop your body. The HPI bodys have cut lines on them for looks. If you race it cut it to fit.
Downforce is offline   Reply With Quote
Old 02-25-2004, 04:55 PM   #1819
rc-zombies's Avatar
jleibund
Here's a pic of mine...similar situation to yours...
and the highest ride height I can go is 6.5mm..as low as 4-4.5+/-
http://groups.msn.com/RCZOMBIES/hpip...to&PhotoID=296
Old 02-25-2004, 04:56 PM   #1820
Those arn't super nitro tires? Hard to tell.
Old 02-25-2004, 04:59 PM   #1821
I bet its the X-pattern tires then. I thought they were a normal 26mm size. What tires are you running? I'd like to compare the diameters to see if thats the problem. I can take a pic without the bumper a bit later. Thanks for all the help everyone!
jleibund
jleibund is offline   Reply With Quote
Old 02-25-2004, 05:02 PM   #1822
RCBuddha's Avatar
Trader Rating: 33 (100%+)
jleibund
I don't think its the x patterns.... Their sidewall profile isn't any taller than other tires.
How are you measuring your ride height?
Buddha
RCBuddha is offline   Reply With Quote
Old 02-25-2004, 05:04 PM   #1823
I'm measuring from the ground to the bottom of the graphite chassis - maybe that is the problem? The wheels/tires measure 65mm in diameter overall.
Old 02-25-2004, 05:05 PM   #1824
roughly 2.5" in diameter with tires
Old 02-25-2004, 05:06 PM   #1825
Or maybe I'm not measuring the droop correctly - I was using the droop gauge, setting the chassis flat/square on it and measuring the A-arm at the center of where the knockle pin enters the end of the arm.
Old 02-25-2004, 05:07 PM   #1826
RCBuddha's Avatar
If you could, please take a pic of the car looking at it from the side. I'm still not sure how your getting 11mm of ride height if you built the car as per the instructions....
Buddha
Old 02-25-2004, 05:07 PM   #1827
rc-zombies's Avatar
droop has nothing to do with ride height...
I just measured my HPI 33R tires... they are 60mm
Old 02-25-2004, 05:11 PM   #1828
OK, here is the car from the front - compare it to the picture of zombie's - there is definitely a difference!
Old 02-25-2004, 05:12 PM   #1829
And from the side, as requested...
Old 02-25-2004, 05:14 PM   #1830
I figured out my problem. Have anyone moved the servo further to the front to get more room for esc and reciver? I think I`m going to do this. Any comments?
I`m using a novak gt7 and it is quit big
sturla is offline   Reply With Quote
SEO by vBSEO 3.5.0
