Old 02-25-2004, 02:20 PM   #1801
lazyboy's Avatar
Send a message via AIM to lazyboy
troy the car did look good on the track and i have to say you looked alot faster maybe its because of the shaft but who know and to make your car look even cooler was that awsome mazda 6 body
lazy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 02-25-2004, 03:17 PM   #1802
OK,
So here is my question with ride height. As you can see in this picture, the wheels are slightly 'out' of the wheelwells. I'm using the factory default settings, droop=6, second hold on the tower in the front. My shock springs are in the most relaxed position near the top (pre-load collars are at the top). All of the electronics are onboard, yet there is absolutely no compression of the shocks at this lightest setting.
If you read the manual, the ride height should be ~4.5mm in the front, yet mine is around 11mm as pictured. I don't know how to get it down to 4.5mm without increasing droop, since the shocks don't compress at all at stasis from the weight of the electronics. Am I missing something here? At the very least, something doesn't add up with HPI's recommendations in the manual - the only way I can get down to 4.5mm ride height is with a droop of around 8. They also refer to ride height adjustment as adjusting the shock pre-load collars, but mine are as loose as they get. That is, they don't seem to have an effect on ride height.
I don't know anything about chassis setup, any suggestions?
jleibund
jleibund is offline   Reply With Quote
Old 02-25-2004, 03:20 PM   #1803
Hi
I`m almost done buliding my pro4. My arms hurt after all the screwing But one big problem came up. It seems to me that I can`t use pinion gears lower than 32 or something. Anyone else with that problem. If that is so, I don`t think you can use it on smalltrack with a mod engine. With final drive ratio with 8 and higher....
please help
sturla is offline   Reply With Quote
Old 02-25-2004, 03:21 PM   #1804
rc-zombies's Avatar
adjust ride height by the shock collars...not the droop screws.
what springs, oil are you using?
lets see a front/rear view of the shocks without the body.
Old 02-25-2004, 03:23 PM   #1805
rc-zombies's Avatar
Originally posted by sturla
Hi
please help
You should have used a power screwdriver...when it gets to the head of the screw..you stop and hand tighten it...
are you using the stock 96t spur gear? I've got a 34t in right now and still have plenty of space to move the motor in...
Old 02-25-2004, 03:24 PM   #1806
Registered User
you should take a close picture of the tower and shock mounting with the body off so we can see whats going on
J FAST is offline   Reply With Quote
Old 02-25-2004, 03:32 PM   #1807
I'm using the shock oil that came with the kit and the copper-colored springs that came with the kit, specified for the frontend. I'd like to be able to adjust with the collars, but its not having any effect on ride height. Here is a close-up without the body.
Old 02-25-2004, 03:42 PM   #1808
RCBuddha's Avatar
Trader Rating: 33 (100%+)
its hard to tell from the pics, but did you put the correct amount of spacers under the arm mounts?
RCBuddha is offline   Reply With Quote
Old 02-25-2004, 03:44 PM   #1809
Another shot
Old 02-25-2004, 03:44 PM   #1810
rc-zombies's Avatar
Who's spring cups are you using....they don't look like the black stock pieces....
I'm using the HPI purple spring cups...and I'm able to get 5mm ride height with no problems.
Old 02-25-2004, 03:44 PM   #1811
One last one...
Old 02-25-2004, 03:46 PM   #1812
Yeah, I used the 2mm spacers in front per the instructions.
Old 02-25-2004, 03:46 PM   #1813
lazyboy's Avatar
or did u ever think that the wheel wells are a lil big so that the tire can move freely with out rubbing and or the body is a lil bit high, and also can make a body look like that
Random Guy
FT B4
Trackside hobbies
Old 02-25-2004, 03:47 PM   #1814
Yeah, I'm using the same purple HPI option parts you are. They have about the same amount of space as the factory black ones... I measured them.
Old 02-25-2004, 03:49 PM   #1815
My only conclusion with the body is that it may not fit the pro 4 well. I have it seated so that it touches the top of the front shock towers, it won't go down any further. Still though, my ride height is 11mm and others have gotten theirs down to 5. It doesn't answer that issue.
