Like Tree5Likes
Old 02-25-2004, 07:51 AM   #1786
JusBox's Avatar
what's that little collar for anyway? I'm guessing it's so the bearings fit the gear but why wouldn't they just use a gear that fits the bearings? Why are they introducing more parts into a diff that don't seem necessary?
JusBox is offline   Reply With Quote
Old 02-25-2004, 08:06 AM   #1787
It might be a manufacturing cost/benefit issue: the front and rear bevel gears are identical and probably more expensive to produce if they are different. It might be less expensive to just add the plastic collar for the rear diff since precision bevel gears are obviously more expensive to manufacture?
jleibund is offline   Reply With Quote
Old 02-25-2004, 08:08 AM   #1788
pucho's Avatar
Send a message via AIM to pucho
My guess is so they don't have to make a seperate gear for the oneway as asc does eaven the Xray the oneway pully and the diff pully are different.
pucho is offline   Reply With Quote
Old 02-25-2004, 08:20 AM   #1789
Erik Shauver's Avatar
Erik Shauver is offline   Reply With Quote
Old 02-25-2004, 08:50 AM   #1790
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by Erik Shauver
TSR6 & True R/C Racing: I suspect if the spur stripped due to motor movement, that the cap screws were maybe a touch loose? TSR6, I definately recommend a ball driver for the motor install. I've gotten away without it on one occasion, but felt as though I was tempting fate . If the motor moved because of the impact... WOW Sounds like TSR6 had a good night racing all the same .
-E
Erik - Yeah, I planned on buying a ball driver last night, but did the "Ahhh, I can get it for now" attitude.
The screws were tight, but not tight enough obviously. It was quite a hard hit too, on power even. The car held up, which was surprising because it was one of those hits that you cringe as it happens.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-25-2004, 08:57 AM   #1791
JusBox's Avatar
AWOLsoldier: The two primary reasons would be to reduce the number of process steps for production (no secondary ream for one-way gears, less production defects), and to reduce the number of new parts needed for customers and hobby shops (i.e. the same gear is used for diffs and one-ways). It also offers flexibility in how to apply the gears to different platforms and projects.
-E
I see... thanks for the info.
Old 02-25-2004, 08:59 AM   #1792
rraden's Avatar
Trader Rating: 229 (100%+)
Couple of comments on the diffs:
First, I thought the US versions came with diffs at both ends but to my suprise there is a one-way. Bought my kit at Ultimate Hobbies. I hope the local supply chain has diff assemblies available soon.
Secondly, I compared the bevel gear with the Associated one and it is very close! Maybe a direct replacement, the gears mesh perfectly. The ratio may be different though and I didn't compare the inner ID opening.
Thirdly, I'd be curious if most people breaking teeth on the bevel gear, was it the one on the one-way? With a one-way or a spool when an accident occurs the weakest link in the drive train will break first. Sometimes it's the gears and sometimes it is the drive cups on the drive shafts.
Comments on these?
rraden is offline   Reply With Quote
Old 02-25-2004, 09:11 AM   #1793
Erik - I'm running the mod setup. I'll try to post a few pics this evening after work...
Old 02-25-2004, 09:26 AM   #1794
RCGaryK's Avatar
Troy, we normally cringe when you are on the track, but for other reasons
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 02-25-2004, 09:45 AM   #1795
Old 02-25-2004, 09:47 AM   #1796
RCTech Member #2
TSR6's Avatar
Ouch
Thats ok, It's just Gary.
He may cringe when I am on the track, but I cringe when I see him walk in the door. I just act all nice and friendly so he doesnt hack me.
Troy
RCTech Member #2
Old 02-25-2004, 09:57 AM   #1797
rc-zombies's Avatar
Great job Troy...
see... didn't I tell you the car was great out of the box....
Old 02-25-2004, 10:12 AM   #1798
RCGaryK's Avatar
Yeah, well, at least I have enough car control so that you know it was a deliberate hack and not just bad driving
HorizonHobby.Com
Old 02-25-2004, 11:11 AM   #1799
RCTech Member #2
TSR6's Avatar
Man!
Anyone else care to rip on me while we're at it?
Edit - Gary, the results are on Trackside's website now.
Troy
RCTech Member #2
Old 02-25-2004, 12:23 PM   #1800
rc-zombies's Avatar
Anybody need sway bars?
Pro4 1.2mm & 1.4mm Sway Bars.
