Old 02-23-2004, 09:19 PM   #1756
You can also get the car from www.speedworldraceway.com 289$
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Old 02-24-2004, 07:19 AM   #1757
Send a message via AIM to Proteus
I was at Ultimate last night and they have about 6 or so kits on the shelf. I ended up picking up a spare Pro4 to use as parts. Okay...well, it actually started out to be a spare parts kit, now it's turned into a back-up kit. Maybe it'll turn into a second class kit...lol!!!!! This time I'm doing the bath treatment to the gears. Hoepefully, the spares will be out by then that I won't have to canibilize the 2nd kit.
Proteus is offline   Reply With Quote
Old 02-24-2004, 07:48 AM   #1758
snoopy's Avatar
Originally posted by Downforce
Yes it does, but it's a rubber tire body. You have to cut most of the chin spoiler off to keep if from dragging on the carpet w/foams.
That sucks.....i've been waiting for them to come in, now i'll have to stick to my alfa or mazda 6..
snoopy is offline   Reply With Quote
Old 02-24-2004, 01:24 PM   #1759
im thinking about getting the pro 4 can u guys give me some info why its good and advantages/disavanges of this car compared to others ie xray
craziracer is offline   Reply With Quote
Old 02-24-2004, 05:02 PM   #1760
robk's Avatar
Trader Rating: 22 (100%+)
Seriously, is there a date for spare parts to start appearing? Especially diffs or diff halves??
Old 02-24-2004, 05:14 PM   #1761
Registered User
I mess up using CA on plastic ring to Diff gear. CA dry too fast before I can make it flat with bevel gear. I need new bevel gear and nobody have it in stock.
Aku-Man is offline   Reply With Quote
Old 02-24-2004, 05:16 PM   #1762
Erik Shauver's Avatar
Erik Shauver is offline   Reply With Quote
Old 02-24-2004, 05:19 PM   #1763
snoopy's Avatar
What are u using CA on there for anyway? The instructions don't tell u use CA.
try http://www.rcmodel.com.hk/ for spares
Old 02-24-2004, 05:37 PM   #1764
Registered User
Page 14 in manual.
They don't have it in stock.
Old 02-24-2004, 06:04 PM   #1765
snoopy's Avatar
Page 14 in manual.
It's page 15, and the diagram tells you to use "SILICON GREASE"
try jet hobbies
http://www.jethobby.com/
Old 02-24-2004, 06:06 PM   #1766
JusBox's Avatar
try jet hobbies
lol, that's quit a mixup right there.
JusBox is offline   Reply With Quote
Old 02-24-2004, 06:13 PM   #1767
Old 02-24-2004, 06:46 PM   #1768
Registered User
That is what I'm talking about Erik. Thanks for the tip.
I have CA Debonder, but I'm afraid it might melt the plastic spacer and gear. Well, no hurt to try. I was going to throw that gear away anyway. If Debonder don't work, I might just drill that spacer out and the gear can still use for front one way.
Old 02-24-2004, 06:58 PM   #1769
Thanks Little E.
Downforce is offline   Reply With Quote
Old 02-24-2004, 07:15 PM   #1770
snoopy's Avatar
Originally posted by Erik Shauver
Aku-Man: Sorry to hear about the CA mishap... on the next set, assemble the plastic spacer (ring) into the gear first, then add a small drop of thin ca and run it around the spacer by tilting and rotating . Hope this helps. I think you are refering to the small plastic ring that goes into the bevel gear (73501) at the top of page 14.
All may not be lost if you can find some CA debonder.
-E
Looks like you Guys in the US get a different manual to the rest of us...Ours is on page 15 and does'nt show the use of CA anywhere......what gives??
