Old 02-23-2004, 09:51 AM   #1741
rc-zombies's Avatar
After soaking the in the Hot Tub...
I've had about 10 practice runs on mine and diff gears still like new... no problem with durablity.
Old 02-23-2004, 09:57 AM   #1742
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by AWOLsoldier
Yah I figured that was a bit harsh so i edited it... I've never had much luck with molded diff cases, etc in the past so i avoid cars that have those. Look at the tc3, sure it's successful but you have to do so much to it to get it to run the way most people want it. No excuse for the diff gears, you shouldn't have to soak them in hot water for them not to fail. And I honestly believe that any new car you own is "the best ever". That really doesn't mean that much.
AWOL - I'm going into this with open ears. I haven't run the car yet, but my impression from building it has me smiling ear to ear. The last car I had this much fun with before even running it was my Losi XXX-S, which I was fairly successful with ( for example, I was the only belt car in the rubber A at the Novak USTC)
I don't even know if you "have to" soak them in hot water, but being a car without full parts support yet, I'm not taking any chances - nor do I think anyone else should.
I remember when the TC3 came out, being a Pro2 guy, we were all laughing at the TC3's breaking suspension arms. Rome wasn't built in one day.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-23-2004, 10:00 AM   #1743
OSherman's Avatar
Originally posted by TSR6
.....Pro4 problems - The only "problem" I have heard of thus far is the diff gears,... and nobody that has done the "hot bath" has broken them yet ( that I am aware of ).....
that's funny... The person(s) that posted this boiling tip, did so before they even ran the car... so, i ask, was it in fact a problem in the first place?... I really don't recall any reports of problems with the PRO4 'out-da-box'....
maybe i've missed something...
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 02-23-2004, 10:02 AM   #1744
rc-zombies's Avatar
I read many many many pages back...soaking was not nessessary...just a preventive procedure... if a lube is applied and is thin enough..the diff gears will absorb some of that oil.
I had the Pro2 as well... that car was built like a tank...
Old 02-23-2004, 10:04 AM   #1745
RCTech Member #2
TSR6's Avatar
Osherman - It originally suggested by the guys from HPI. I don't remember if Erik posted it here, but it was suggested on the HPI Europe's forum.
I did it out of the box just to "be safe," and have been passing on the "hot bath" (note: I'm keeping away from the term "boiling" ) tip to others who ask how to do it.
Have there been gear breakages? Yes. Can we even be sure boiling would have helped them? I don't know. I guess it depends on the nature of the breakage.
Troy
RCTech Member #2
Old 02-23-2004, 10:04 AM   #1746
JusBox's Avatar
Hey it's all good, opinions are just that, opinons... not worth much in the end.
JusBox is offline   Reply With Quote
Old 02-23-2004, 10:05 AM   #1747
rc-zombies's Avatar
It was posted on the R&D Cafe HPI Japan site.... in it's current state the diffs were too brittle and teeths started to brake...boiling the gears adds moisure back into the parts making it more durable.... Even on the grahite arms of the Pro3 and 'Cuda...they recommend boiling the parts.
Old 02-23-2004, 10:49 AM   #1748
V12
V12's Avatar
Default Re: springs
Originally posted by al jones
can someone tell me the rates of congo springs.
Congos are
yellow 40 lbs
purple 35 lbs
blue 30 lbs
V12 is offline   Reply With Quote
Old 02-23-2004, 11:53 AM   #1749
I assembled most of the kit this weekend. Its looking sweet. Just waiting on the alum rear knockles from HK to finish it off this week.
In the meantime, does anyone know where I can find suitable replacement posts for the rear end, preferably anodized alum? zombie, I picked up a pair of those HB 60mm for the frontend, they're great!
I'm reticent to cut the factory parts to size just for one of my several bodies (some of which need larger posts) and I haven't seen the factory replacement parts out there for the rear posts. I suppose if I had some metalworking bits, I could just adapt a set of the HBs, but I'd rather buy something intended for that purpose.
jleibund
jleibund is offline   Reply With Quote
Old 02-23-2004, 11:58 AM   #1750
rc-zombies's Avatar
jleibund
The rear body post will be out shortly by Tobee Craft or Product D.
I'm dissappointed with there past items...they don't match the HPI purple very well... I just got the new alum. driveshaft cups...they're more pink than purple.
http://www3.kcn.ne.jp/~tobee/pro4%20english.htm
Old 02-23-2004, 12:30 PM   #1751
Yeah, I noticed the same thing and kept the center cup joints, but passed on the dogbones when I got them and went with HPI's.
Thanks for the info.
Old 02-23-2004, 03:14 PM   #1752
robk's Avatar
Trader Rating: 22 (100%+)
Integy also has clamping hexes from the Atlas cars. They are very nice and the color is very close to HPI..
http://integy.automated-shops.com/cg...08104115961.0a
Old 02-23-2004, 07:42 PM   #1753
Hey guys has anyone bought the new hpi stratus body for the pro 4? If so does the body have the dimples on the body for the pro 4. Thanks
LSR SPEEDWAY
R1 WURKS
Schelle Racing
MIP Racing
BN Racing
bigdog is offline   Reply With Quote
Old 02-23-2004, 08:01 PM   #1754
Yes it does, but it's a rubber tire body. You have to cut most of the chin spoiler off to keep if from dragging on the carpet w/foams.
Downforce is offline   Reply With Quote
Old 02-23-2004, 08:25 PM   #1755
can get pro 4 from www.ultimatehobbies.com
cencalballer is offline   Reply With Quote
