Like Tree6Likes
Old 02-22-2004, 10:21 AM   #1681
rc-zombies's Avatar
Originally posted by TSR6
zombies - guess thats what happens when you don't pay attention. Great minds think alike, no?
i should post a picture of my hand, with the two red lines across it - One on my palm, one at the bottom of my fingers.
Old 02-22-2004, 10:23 AM   #1682
rc-zombies's Avatar
Originally posted by Chrisgt2
Anyone think a diff from another car would fit in the front?? with some mixture of parts........maybe?
Just in case they are hard to get a hold of for a while.
I already tried to fit the cuda diff and gears since they both share the same drive ratio... but no can fit...
Old 02-22-2004, 10:25 AM   #1683
rc-zombies's Avatar
Originally posted by David Joor
Uhm, HPI care to comment? I don't see them not releasing steel diffs due to the fact the option is available on their setup sheet and you can't run mod foam carpet with accuracy and efficiency with a delrin or molded diff halves.
hmm...maybe I spoke too soon... but I don't see Hara or the HPI drivers having problems with Delrin diff in mod... but then again..we are not Hara...
Old 02-22-2004, 10:26 AM   #1684
rc-zombies's Avatar
Default Re: who sells parts stateside
Originally posted by jbackslash
I need parts. Anyone know where I can buy them stateside yet? Took the pro4 out tonite and I liked it until I shattered the front bevel gears. Maybe next time I will boil the gears.
haven't seen any parts yet in the state...Tower has all the parts listed already... you best bet for parts if RainbowTen or RcModel.
Old 02-22-2004, 10:28 AM   #1685
rc-zombies's Avatar
Default Re: PRO4 in transit!
Originally posted by yobbism
My Pro is on its way.
Wil be nice to retire the Pro3 but sad aswell, its hard to heard bad words from you guys about a pro3 but you get that.
Although it makes me think ive been driving a piece of crap and winning. either way.
Pro4, cant believe its comming.!!!!
That piece of crap was great car to me...had much success with it. no matter what others say...even though I put alot of $$$$ into it... the car was fast and handled very well...
Old 02-22-2004, 10:30 AM   #1686
rc-zombies's Avatar
Default Re: ???????????????????
Originally posted by shortyzz
Hi guys
I was lookin at purchasing a Pro 4 over the net, do you know were i can get one for a good price and if they will ship to Australia, also because my local hobby stores wont carry alot of the Pro 4 gear what else should i purchase (spares, Hop-ups etc)
Thanks guys
WADE
Order the car and parts from RcModel...just hope you don't have too high of a Duty tax...if any...
Old 02-22-2004, 10:31 AM   #1687
rc-zombies's Avatar
Originally posted by Why Try?
Theres already 2 running local tracks in brisbane.both are doing really well in stock so far.I think they sold for about $695 in the shop.
$695 UDS? man that's expensive...and I thought Tower was way too much at $444
Old 02-22-2004, 10:33 AM   #1688
rc-zombies's Avatar
got the wires cleaned up, it's ready to rock.
Those Twisters sure looks good in the car... I've got one as well... do you have the PC programmer as well? if you don't highly recommend it..
Old 02-22-2004, 10:39 AM   #1689
Anybody try, TC3 front spool in Pro 4 yet? Use PRO4 one way gear instead.
racingdc9 is offline   Reply With Quote
Old 02-22-2004, 10:39 AM   #1690
rc-zombies's Avatar
Originally posted by racer
under closer inspection i cracked my front bumper
That's the one part I think that needs beefing up and or adding a wider piece of ABS plastic. I tried fitting the wider from bumper from the Nitro...but didn't fit.
Instead of using the countersunk screw... I place a flat countersunk washer instead..it will hopefully displace any inpact and hopefully not crack it... I found from the past that the countersink screw will crack in that area first duing a hard frontal impact....
Old 02-22-2004, 10:41 AM   #1691
rc-zombies's Avatar
I have one and they will not fit... different size and design.... can't mix oranges and apples....
Old 02-22-2004, 01:41 PM   #1692
Why Try?'s Avatar
Thats aussie dollars zombie bought them in local hobby shop.
TM E4
Axial Ax 10
Savage X
HobbyOne
Why Try? is offline   Reply With Quote
Old 02-22-2004, 01:46 PM   #1693
rc-zombies's Avatar
OIC...
what's that come out to in US $$$
hope not anymore than what we're paying.. so far $285-290 has been the going price..
Old 02-22-2004, 02:12 PM   #1694
rc-zombies's Avatar
Default TRANSPONDER HOLDER/SERVO SAVER
A couple of new option parts released by Jet Hobbies
Transponder holder/servo mount, servo saver linkage.
Pro4 decals now available too....
Old 02-22-2004, 02:37 PM   #1695
Send a message via AIM to Proteus
Default Wow!
Well here's the report after my first race with the Pro4. The first pack I ran was the stock setup according to the manual. I ran stock class using a monster motor. The only changes I made was using Losi 50w oil in the front and 40w oil in the rear. Tires were Sorex 32's with hpi green insert on yokomo wheels. I was running at Socal in Huntington Beach, CA. I wanted to race the 19t class but decided to take it easy on the car since no spares are available yet.
First pack: I was very surprised with how well the stock setup worked. The car had plenty of steering and good steering in/out of the turns. The car setup, however, I found was too soft. There was a lot of body roll and just a tad too much steering. But overall, I was impressed how easy it was to drive. I didn't push the car too much. I was just trying to get the feel of the car.
Second pack: This time I took the rear sway bar off and changed the springs. I used TC3 golds in the front, and blues in the rear.
Impression: WOW!! I had alot more corner speed, but the car still had too much body roll. As I became more confident with the car, I pushed it a little harder. Although the car transitioned pretty well, it still wasn't enough. The one problem I see is that there is too much toe in the rear. 3 deg is more than I'm used to. I think 2 deg would be plenty on asphault with rubber tires. The other thing I noticed was that the car was squatting too much in the rear. At 5mm ride ht, I didn't expect to bottom out, but it was evident at the rear corners.
Third pack: I decided to add some anti-squat. This helped a tad. By now I was quite comfortable with the car. I was surprised that everytime I really pushed the car, it just kept going.
Fourth pack: I dedided to raise the roll center in the front of the car using the camber links. That helped alot as it kept the front end from rolling too much in the turns.
In qualifying, I did farely well, but only managed to qualify 9th; tough competition. 3rd qualifer through 10th qualifier was only seperated by about 5-6 seconds.
I ended up taking 3rd in the main. It was amazing to see how easy I was just reeling in the other cars ahead of me. I did notice that most of the cars were just going through the turns too slow, whereas I was able to stay on the throttle. My fastest lap was a 11.7 with lots of 11.8's and 11.9s. My fastest lap with the previous car (XXXS) was an 11.8, but few to rare with most being in the low 12's. The funny thing is that it took me almost a month to hunt that setup on the losi just to hit 11.8, whereas the Pro4 I hit 11.7 with it's first debut. Not bad, since that I know with some more tuning I can get it down to the low 11's.
Overall impression: Look out! The Pro4 is no joke.
Damage report: Nothing visible from the outside. When I got home though, I had my car on the table and as I was manually turning the rear wheels to see if the bearings had freed up even more, I heard a click in the front transmission every once in awhile. After pulling the diff case apart, I found that the diff gear was missing about 5 teeth and the input shaft gear was missing about 5 teeth as well. BUMMER! I guess I'll just have to run it and til It ends up stripping all the teeth off or the spares come in. On another note, one other guy had a Pro4 at the track. After the second qualfier, he had to pack up and go home. It seemed that his diff case exploded, the part that you screw down by the input shaft. His diff gear and input shaft gear was toast, stripping most of the teeth off.
HMMM...Can't wait for the option stuff to come out.
GOOD JOB HPI
Jeff
Proteus is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
herffstyle
