Hpi Pro 4
Dammit you're right! I've ordered BD508!
Shitty Yokomo reference system
I will order the right one... Thx a lot!
Sway Bar Problem
Hey Pro 4 Family! I installed the copper sway bar - 1.2mm(item # 6824) on the chassis. There is alot of play because the m3.2×5mm grub screws(item # Z775) is not able to stop the sway bar from having too much play. Does anyone have the same problem?
You have to screw the grub screw on an angle to Touch the swaybar
Thanks GTR r34. I can't believe HPI would have a design problem. It might be hard to put those screws in an angle against the sway bars. Lucky the car doesn't really need the 1.2mm sway bars to run well.
It would be good if the new HPI will continue to make older HPI parts (like Pro 4 parts)?
Take Care
Take Care
TC4 Axles on Pro 4...?
Are Team Associated TC4 Axles the same as Pro 4 Axles(item# 80824)?
Thank You
Thank You
The axel or the dog bone part?
Pro4 owner
It would be nice to see a pic of everyone Pro4
No, the Pro 4 are for metric bearings an take an M4 locknut. Magically Sheldons has some still...
HPI #80824 - MIP CVD AXLE (2pcs) ? Sheldon's Hobbies
Hey RAL; I agree. . .magic. . . . .
I was think'n about getting axles from Sheldon Hobbies. But they're probably used - with some wear. I don't buy used R.C. Stuff. . .
It looks like My Pro 4 is a Shelf Piece.
Pro4
Picture of my Pro4
Thank to Exotek Racing
