Like Tree5Likes
Old 01-07-2015, 10:22 PM   #15856
Trader Rating: 51 (100%+)
Miss my pro4 exo .....great product's ...any plans tc4 ? I realize it would have more parts but it's hard to find parts for pro4 these days and tc4 are some a dozen....
Rick Hess
Sworkz USA-Amain Hobbies
R&C Hobby Shop Clarksville TN
-RCJuice-HobbyStar-RCP Customs-AKA-Protek RC
rkhess is offline   Reply With Quote
Old 01-07-2015, 10:37 PM   #15857
i wish i will get Ferrari soon...
Hexder is offline   Reply With Quote
Old 01-11-2015, 06:43 AM   #15858
Asking for help: may somebody suggest me where to get the Pro 4 gear box spare parts (#73511). Much thanks!
donatelli is offline   Reply With Quote
Old 01-12-2015, 12:41 AM   #15859
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Got my new conversion in. Time to remove the old Exotek chassis and replace with the new.
Lovin' the shiny CF over the normal Exotek dull matte finish.
Dan is offline   Reply With Quote
Old 01-12-2015, 12:09 PM   #15860
Trader Rating: 20 (100%+)
Got mines in too. Unfortunately won't be able to install the conversion until the end of the week. Looks like its time again to revive the good ole pro 4��
goots is offline   Reply With Quote
Old 01-13-2015, 10:46 PM   #15861
Mike,
so is there a different position for steering rack also? I see the motor mount and servo has different positions. But I also see another position where I think the steering rack can go. Also what are the second set of three holes on the center line used for? Any more info on the conversion would be helpful.
Old 01-14-2015, 11:28 AM   #15862
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by goots View Post
Mike,
Hi,
There are 2 other holes in case you wanted to try fitting other cars low profile steering racks. I just use the stock steering rack though as it responds well for me.
The 3 additional set holes will allow the new servo mount to be positioned in 3 locations for weight bias.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-14-2015, 01:04 PM   #15863
Originally Posted by MikeR View Post
Hi,
So I can potentially use the tcx steering rack in the extra position.
Old 01-20-2015, 09:50 PM   #15864
Hi,
so i'm starting to build my V1 to V2 chassis, and what boggles me is the steering rack. What other steering racks will fit into the new position? besides that, I appreciate the thought and work going into this conversion with the new parts, thinner chassis, and multiple positions for servo and motor. This chassis is still capable of winning knowing its 10+ years old
Old 01-22-2015, 08:59 AM   #15865
MikeR's Avatar
I am thinking the EVO6 steering rack system might work. The TCXX or any belt car stering would sit too high and hit the drive shaft I'm afraid. With that being said, I know the Pro4 steering doesn't look modern but I think the geometry and performance suits me fine
Old 01-22-2015, 09:35 AM   #15866
Im using that rack for a similar but different brand project Im doing. The only draw I have with it is the vertical ball mount on it and the servo angle. I'm using Yokomo ball cups and it seems to bind it a little.
Plus side is the Evo rack does have the off center spot too so it helps you clear the driveshaft.
Mike question while you're here .... can you buy pieces to this kit separately? Mainly the battery mounting pieces. Thanks
Robbob is offline   Reply With Quote
Old 01-23-2015, 09:51 PM   #15867
the stock battery center rail cannot be aligned to its holes, it is off by just a small margin. It's no biggie but would like people to know. As for now I'm just using the m3 nut exactly how it was used on the v1 chassis as a battery stopper.
Old 01-24-2015, 08:20 AM   #15868
Hi boys, anybody knows where can I achieve one of these beauties cars?
alejandrospeed is offline   Reply With Quote
Old 01-28-2015, 12:12 AM   #15869
ebay has a deal on a fixer upper right now.
Old 01-28-2015, 12:19 AM   #15870
Dan
Dan's Avatar
Anyone get their new conversion up and running yet? I haven't had a chance to work on mines, been busy with the F1 cars.
