Old 02-19-2004, 02:34 PM   #1561
rc-zombies's Avatar
Originally posted by racingdc9
The kit comes with some already, so they're thinner then the 6mm? I tried looking in the manual, but didn't say how thick the kit hubs are. Different part number. 72044
The stock ones are the 'Thin' type..about 4mm. they supply spacers to widen the car.
Old 02-19-2004, 02:38 PM   #1562
rc-zombies's Avatar
Default Re: Re: Re: Re: 72036 6mm HUBS
Those hubs don't have a "Buy one now" button on the Buy HPI site. So you can't buy them.
I guess I was lucky... They sold out already...
the last time they had them was about 3 weeks ago...
Old 02-19-2004, 02:51 PM   #1563
racer's Avatar
Default Re: 72036 6mm HUBS
Originally posted by rc-zombies
[B]"BUY HPI"
has these in stock again...
These are great if you're running a wide set-up.
With all the wheel spacers in place the stock thin hubs may not have enough grab of the wheel. This was recommended by the HPI R&d cafe Japan.
ordered my set from R10. hopefully they have them.
and regards to the ball diffs, gosh they do go fast. i've ordered two but was only able to get one
racer is offline   Reply With Quote
Old 02-19-2004, 02:52 PM   #1564
rc-zombies's Avatar
Default Re: Re: 72036 6mm HUBS
I've tried getting some from R10 a couple times already... had no luck.
Old 02-19-2004, 03:21 PM   #1565
Registered User
Just received my pro4 today. Can't wait to build it. Love~~~
Aku-Man is offline   Reply With Quote
Old 02-19-2004, 03:24 PM   #1566
rc-zombies's Avatar
That's great... Take your time building the car and take note of the shimming...
Most importantly... don't forget to boil all your beveled gears.
Old 02-19-2004, 03:31 PM   #1567
Erik Shauver's Avatar
Default Hex Hub Adapters 72036 vs. 72044
Erik Shauver is offline   Reply With Quote
Old 02-19-2004, 03:38 PM   #1568
rc-zombies's Avatar
Thanks Erik
I was looking to get these if I weren't able to the HPI 72036
http://integy.automated-shops.com/cg...43104355109.3d
Old 02-19-2004, 03:41 PM   #1569
Registered User
Are you sure, I remember someone melted the gears.
Old 02-19-2004, 03:44 PM   #1570
rc-zombies's Avatar
Yea..that was me that melted the gears.. I wast busy assembling the car and forgot the gears in the pot and it ran out of water...
brint the water to a boil and turn off the stove...and let the gear soak in the hotwater for about 30min... after that take them out and just towel dry them...and don't forget to lube the gears....
Old 02-19-2004, 03:49 PM   #1571
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
GregH at HPI-Europe's forum has been saying not to directly boil the gears, but to boil water, pour it into a different container and let it sit for about 5 minutes, then set the gears in it to soak for about 20 minutes.
Erik - What do you recommend, is it even nessisary?
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-19-2004, 03:56 PM   #1572
Registered User
Thanks. I'll do that. BTW, I'm using paragon ultralon to lube all my gears on SD and I like it. I think I'll use it on pro4 too.
Old 02-19-2004, 04:01 PM   #1573
rc-zombies's Avatar
That's what I used as well... & put some on the main drive shaft pins & outdrives as well...
Old 02-19-2004, 04:08 PM   #1574
Registered User
Thanks zombies.
Old 02-19-2004, 04:49 PM   #1575
Herminator's Avatar
Send a message via ICQ to Herminator
Time for a few questions....
What kind of gearing range is possible with 48dp gears? ie. could I go from 19/72 all the way to 35/72?
Will HPI be releasing parts in the future with a higher graphite content or are the current compisite parts as light/stiff as most other cars optional graphite composite parts?
Any one been crash testing it yet? how well does it stand up to a bit of abuse? (other cars have a habbit of swerving into my path, honest )
Herminator is offline   Reply With Quote
