Hpi Pro 4
I prefer the high traction arms... more durable and more feel on the track.. the cyclone tc arms have more tuning options.. but I have seen so many snap..
i ended up ordering both and a 88t spur so i can qualify for free shipping on myatomic.. i guess ill give both a try
Thanks guys for the advice on the 47/88 gear combo, setup has amazing exit speed and top end
I am trying to pick up a used TC for use in a 21.5 Spec Sedan class at the LHS. I am returning to RC racing after a 20 year timeout so I don't have much current knowledge. I have found local info on Associated, Tamiya, Xray [too expensive for me] but not much on HPI. I assume the HPI cars are competitive with the previously mentioned cars but I would like to know some more about them.
Are there any advantages between the various versions of the HPI RS4? [by model, I mean Pro 2, Pro 3, Pro 4]
Are parts still available?
Do the different versions share a lot of the same parts?
How do they compare to the current HPI TC which appear to be aimed more at non-racers [I may be wrong since this is just an impression that I got when I looked at the website]?
Spares can still be had for the Pro 4 (it shares some with the Cyclone) but you'd have a hard time finding spares for any previous cars IMHO.
The Pro 2 is belt driven and a good car, better than the Pro 3 I always thought. The Pro 4 is still a competitive car but requires some fettling to keep it running well.
If anyone has any questions on the Pro 4 gimme a shout - one of mine for sale here also:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=150446908269
I thought I would post here first, anyone looking for a Pro4..lots and lots of spare parts, 4 chassis, a 3mm, 2.5mm, 2.0mm..I also have the 3mm top deck and shock towers, spare diff cases, diffs, one ways, C hubs, rear hubs, CVD's..I have so much stuff for a pro4, I just want to get rid of everything..not to sure on the price..$225 plus shipping and I'll toss in a new body and a servo (Futaba 9450).
gearing help
hi all i've just picked up a pro 4 to give touring a go. i'm going to running speed passion gt 2.0 lpf with a losi 17.5 bl motor, now the only spur i've got is a 78/ 48dp now what pinion size would be good. i have done a search but the only gearing is all 68 dp and not the 48dp.
Cheers Ginge
Cheers Ginge
what other steering blocks will work on the Pro4/Cyclone ???
looking to replace mine with ally steering blocks but cant find any for Pro4/Cyclone.
can any won help? i'm been signed upto race it this friday
Ginge
Ginge
Cheers Ginge
Cheers Ginge
gearing on the car will depend on what software you running on teh esc.
If new supercharge software you would need to gear around 6 - 6.5 and if older 110 software around 5.5 - 5.
If older software keep gearup watching lap times for a peak and not exceeding a motor temp of 65-70 deg/c max.
Unless where you race has restrictions the latest software is needed to be fairly competitive.
My Pro4..this car still rocks..
have a race in the OC this weekend, now ima run spool and getting the suspension settings re-done so lets hope i make A main
Why a spool? Just wondering..
