Like Tree6Likes
Old 05-04-2009, 06:06 PM   #15601
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Originally Posted by tc3 racer sc View Post
hi i wanted to put brushless in my pro 4 but the motor will not sit right what i need to do i hve the after market purple motor mount what i need to do i hve a novak brushless system thxs reggie
The cutout in the chassis for the motor can hit the endbell on some motors. Might need to file or dremmel it a bit.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 07-22-2009, 03:57 PM   #15602
Super Steve's Avatar
Send a message via AIM to Super Steve
Has anyone been using aftermarket ballcups?
Which ones will clear under the wheels?
Super Steve is offline   Reply With Quote
Old 07-25-2009, 06:07 AM   #15603
Pit-racer's Avatar
pro4 is running great!
Pit-racer is offline   Reply With Quote
Old 07-26-2009, 10:09 PM   #15604
er...
kkk nice post?
anyways, anyone try aftermarket ballcups that clear under the rims?
Also,
are there shiny CVD bones or steel CVD bones that is same length as the stock aluminum bones? (maybe from pro 2 or something?)
My front bones are bent and I need new ones to replace them, but i rather get something stronger because the front ones like to bend... LOL
Old 07-26-2009, 10:24 PM   #15605
TeckLancer's Avatar
Trader Rating: 16 (100%+)
get the losi lcds they work great
they sell them here.
there made for the cyclone but work with the pro4
http://www.speedtechrc.com/store/ebp...id=472&id=8509
or u can also use the AE tc4 tc3 ones. they also fit
Eric Arellano
TC5,RC18-b,PRO4,FS,EIGHT-E 2.0,TLT,TF-5,Nitro MT
Panther tires, Speedtech r/c, Murfdogg Motorworks
check oout my forsale thread http://www.rctech.net/forum/r-c-items-sale-trade/401576-wts-b44-b4-losi-8e-hpi-nitro-mt-few-lipos.html
TeckLancer is offline   Reply With Quote
Old 07-26-2009, 10:59 PM   #15606
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
correction: those are hot bodies DCJs. Same concept and even similar look to the Losis...just different name. DCJ is more accurate than Xray's or Losi's names anyways. Double Cardan Joint. Thats all it really is.
Syber Serulean is offline   Reply With Quote
Old 09-28-2009, 11:55 AM   #15607
For people running solid axle, are you guys using the HPI unit?
Are the solid axles made for cyclones a direct fit?
Old 09-28-2009, 01:53 PM   #15608
solid axle as in spool? Front spool/solid axle from the cyclone wouldnt work because its belt drive and the pro4 is shaft drive...
Old 09-29-2009, 11:31 PM   #15609
o...
I was hoping that it would.
since the width is the same.
I guess where the gear mounts are centered differently?
Old 09-30-2009, 01:04 AM   #15610
the pro4 uses a bevel gear to drive the front spool's gear...the cyclone uses a belt on a pulley. Two completely different kinds of spools (or even diffs for that matter).
However, if you take the diff balls out of the pro4 diff and place some sandpaper in there and tighten it all the way, you'll essentially get a spool by doing that...and it has a little bit of slip incase of accident so you avoid bending CVDs.
Old 09-30-2009, 09:46 AM   #15611
Yes, i realize that cyclone is a belt drive and pro4 is shaft, completely different like you said.
but I dont see why this would stop a spool from a cyclone to fit in pro4, since they are same overall width and same bearings are used, the only thing that could keep it from being used is if where you mount the pulley is different from where you mount the bevel gear.
Have you tried fitting it? or you just know it wont fit because one is belt and the other is shaft?
HPI's
http://www.hpiracing.com/graphics/parts/75168t.jpg
HB's
http://hotbodiesonline.com/graphics/...334_01piw1.jpg
Old 09-30-2009, 10:11 AM   #15612
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
anybody looking for a chassi? I have a brnd new in a pack for 20$ shppd. . . Just holla
pinggoy is offline   Reply With Quote
Old 09-30-2009, 12:29 PM   #15613
why try and possibly fail (thus wasting money) when you can just do this...
worth a shot to do that for free dont you think?
Old 09-30-2009, 12:35 PM   #15614
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Besides, the spool for a Pro 4 is pretty cheap - roughly $15 US. Might as well buy the part that was designed for the task, unless you have access to a Cyclone spool for less money. If that's the case, take the front diff case apart, prepare the spool for installation and see if it fits...
The sandpaper method doesn't sound like a bad idea either...
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 09-30-2009, 01:36 PM   #15615
Kregger's Avatar
You could probably use the TC5 slipper pads if your worried about the sandpaper messing anything up.
I've used them on my pro-2 and it seems to work.
Kregger is offline   Reply With Quote
