Like Tree5Likes
Old 03-03-2009, 02:13 PM   #15571
wheruat's Avatar
koo yah im gonna mess with it tonite and take it out on thur to see how the Pro4 handles vs. Avid. The problem i have is everyone in my area just want to have the fastest ride. for me thats no fun gotta have some turns to show your skills. well ill let you know how it works out. thx for the help
wheruat is offline   Reply With Quote
Old 03-03-2009, 04:16 PM   #15572
Speeds got nothing to do with it. Besides, as the saying goes, slower is faster. And I'm learning that as my lap times are getting lower and lower every week as I stop trying to go too fast. I'm still pretty far behind all the other guys racing, but I'm getting closer and closer. Its not the car though anymore, its me. But I'm practicing and its paying off.
The best advice I can give is like I said. Set it up like hara in the back of your manual. You cant go wrong. Also, shim anything that has slop in it. Arms, c hubs, rear carriers, anything. They should move freely but not have slop.
If I get some batteries I'll try to record the races this weekend and post them. Not that watching me drive is worth much. LOL
Before things get too OT.
Do you guys prefer MIP CVDs or Universals?
And anyone out there reading. If you have a pro4 but don't run it anymore and have some spare parts. Toss me a PM. Looking for pivot blocks(0,0.5, 1, 3), front arms, knuckles, diff gear housings(tops preferred), I'm sure there's more but that is just off the top of my head.
RC-DriftNewb is offline   Reply With Quote
Old 03-06-2009, 06:15 PM   #15573
Anyone out there still running a pro4?
Old 03-06-2009, 07:53 PM   #15574
The pivot blocks, arms, and caster blocks should be a direct fit from the Cyclone.
Yub, yub, cmdr! is offline   Reply With Quote
Old 03-06-2009, 08:44 PM   #15575
Yep, they are.
Old 03-07-2009, 05:25 AM   #15576
Pit-racer's Avatar
I am running a pro4. Getting back into it w/ a tekin rs pro and bl motor.
Pit-racer is offline   Reply With Quote
Old 03-07-2009, 11:29 AM   #15577
I'll be making the move to BL soon hopefully. Just for the sake of not dealing with brushes and stuff...
Pro4's doing good. Really good. And it can take a beating!
Old 03-08-2009, 06:29 PM   #15578
Send a message via Yahoo to infamouse_1
Default pro4 hara edition
About last month I decided to put together my brand new pro4 that I had in the closet for almost 2 and a half years now! and I ran it over the weekend and my rear diff seems to always get loose!!,I also put a teflon nut on it and it still backing out,any help will do.
And the other problem I'm also having is I'm using the front solid spool on the front and when I'm at high speed turning left or right I can here the gears clicking on the front diff. Any help will do also on this one too.
infamouse_1 is offline   Reply With Quote
Old 03-08-2009, 08:45 PM   #15579
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
A lot of people used to replace the diff screw and nut with one from a TC3. I think the TC4 would be the same too.
Its very important to use the shims in the gearbox to have the least possible play between the gears or they will slip!
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 03-08-2009, 10:10 PM   #15580
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
also, spools used with single-joint universals like CVDs tend to make a clicking sound and vibrate a little when at full swing. Xray released double jointed universals and Losi uses their own in the JRXS-R (they call them LCDs and Xray calls theirs ECS).
Syber Serulean is offline   Reply With Quote
Old 03-09-2009, 03:15 AM   #15581
Default pro4
thanks guys for the help i guess ill change out the diff screw and nut,hopefuly it will work and as for the front solid spool ill try and shim it alittle more but if still the same ill just go back to the one way spool.
Old 03-09-2009, 08:59 AM   #15582
Does anyone know which online shop have Pro4 oneway gear in-stock?
G2B Anthony is offline   Reply With Quote
Old 03-09-2009, 10:38 AM   #15583
wheruat's Avatar
i think speedtech has some in stock
Old 03-09-2009, 12:32 PM   #15584
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
If anyone is looking for a HARA Twister speed control to match their Pro4, let me know via Private Message!
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-09-2009, 12:53 PM   #15585
Hey awesome. A little traffic in the pro4 thread.
I've heard of people running AE diff screws in the ball diffs as well. I still have problems with them backing out. So I started using a little thread lock, and it working fine. I'll have to give the tc3/4 thing a try next time. I've also read though, that a worn spring will cause loosening as too.
Like Pablo said, shim it! I learned my lesson of what improperly shimmed stuff can cause.
Wheruat - You race your pro4 yet??
