Like Tree5Likes
Old 05-22-2008, 03:02 PM   #15496
new hop up for pro 4.. cyclone TC arms work in them. more lower shock mounting positions. #67717 Carbon graphite suspension arms
bionictony is offline   Reply With Quote
Old 05-28-2008, 08:53 AM   #15497
Send a message via AIM to GuyIsDamGood
I haven`t been on this site in months and Nothing Changed.
-I thought everyone would have put their Pro 4`s away by now.....?.....I was wrong.....Ha Ha!
There`s very little Pro 4 parts available out there; so be carefull when you Run/Race it. . . . .-My Pro 4 is on a Shelf(I`ve had it for 3 years). I don`t want to take the risk.
For a good Set-Up: -Stay very close to the stock build.
-I don`t use the 1-Way(it`s crazy).
-The Spool works very well on Asphalt that is prepped(a good sweep). But you will kill Ring Gears if you`re hard on the throttle and brakes. . . . .Best with Stock and 19-Turn Motors.
Take Care
GuyIsDamGood is offline   Reply With Quote
Old 06-24-2008, 07:02 PM   #15498
shadow102's Avatar
Trader Rating: 21 (96%+)
ok need to ask you guys a setup question...the pro4 is my main car for the time being until i can upgrade to the latest and greatest. The car runs great but i am having some oversteer under braking and low speed driving sometimes high speed but not as much. I am wondering what i can do to increase the rear grip of the car. I am running the thad garner '05 reedy race setup just without a rear sway bar and the 1.8mm sway up front, with Sorex 36r's all around on outdoor asphalt. thanks for any help you guys can give i am sorta new to the touring car thing and with all the adjustments i am not sure where to start.
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 06-27-2008, 11:08 AM   #15499
Hey shadow; to reduce some of that Oversteer.....install Softer Rear Springs.
-If you are using the Front Spool or 1-Way you should be alright.
-Check the Rear Diff; a Tight Rear Diff can cause some Oversteer.
Don`t kill that Pro 4. Parts are getting Hard To Get.
Take Care
Old 06-27-2008, 11:20 AM   #15500
shadow102's Avatar
ok sounds good i am using the front spool. It looks like i am going to try some softer rear springs then. And dont worry besides a cracked a-arm the car is still doing great. It only needs to last threw the season and i think i have enough parts to keep it going
www.nexusracing.com
www.go-rc.org
Old 06-27-2008, 12:24 PM   #15501
RC MARKET's Avatar
Rear shock Silver or blue !
RC MARKET is offline   Reply With Quote
Old 06-28-2008, 10:56 AM   #15502
TeckLancer's Avatar
Trader Rating: 16 (100%+)
suspension parts are still abundant so dont worry about that
Eric Arellano
TC5,RC18-b,PRO4,FS,EIGHT-E 2.0,TLT,TF-5,Nitro MT
Panther tires, Speedtech r/c, Murfdogg Motorworks
check oout my forsale thread http://www.rctech.net/forum/r-c-items-sale-trade/401576-wts-b44-b4-losi-8e-hpi-nitro-mt-few-lipos.html
TeckLancer is offline   Reply With Quote
Old 06-28-2008, 11:04 AM   #15503
shadow102's Avatar
yeah i am wondering what parts are getting scarce because i really havent had a problem finding anything yet
www.nexusracing.com
www.go-rc.org
Old 06-28-2008, 01:07 PM   #15504
Kregger's Avatar
I've had problems finding the rear shock tower.
Kregger is offline   Reply With Quote
Old 08-07-2008, 08:00 PM   #15505
I new this Pro 4 spot would die down.
But anyway; I raced(mostly just ran it); but I ran it for the 1st time with the Spool installed. . . . .It runs very well. I`ll never run a R.C. Car without a Spool again. It totally out-ran My Evo 5 by 3 seconds(both kits have the same electonics). I ran the kit very close to the box set-up.
Take Care
Old 08-08-2008, 08:18 AM   #15506
scootr117's Avatar
I pulled the electronics out of mine til the next Challenge race....
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 08-10-2008, 12:55 AM   #15507
Xtant3150c's Avatar
I've been racing my Pro4's for the past couple of years now.
One in our Trans Am class (6 cell Nimh Silver Can) and in our 27t brushed/17.5 brushless class and both cars have been running very well!
I have some spares but don't think I will really need to worry to much as we use Road Rails for our track although 2 sides of the track are asphalt curbing! So as long as you don't go wide your usually o.k.
The only issue I had with my Hacker 17.5 brushless powered Pro4 is having to pick up pinions from 52-59 tooth!!!!
space for rent
Xtant3150c is offline   Reply With Quote
Old 08-10-2008, 10:02 AM   #15508
TeckLancer's Avatar
is it hard to fit pinions that size?
Eric Arellano
Old 08-10-2008, 03:15 PM   #15509
shadow102's Avatar
depends on your spur size, The problem i was having is at some point the motor mount just runs out of material to clamp to
www.nexusracing.com
www.go-rc.org
Old 08-17-2008, 02:10 PM   #15510
shallabal's Avatar
Default PRO-4 stuff for sale
I have three custom painted bodies cut for a Pro4, plus a lot of tires, tools, power supplies, and others to sell. Please respond to my email addy for more info.
shallabal is offline   Reply With Quote
