Like Tree5Likes
Old 10-10-2007, 04:56 AM   #15421
Andysan's Avatar
Hi all,
I've recently got some titanium CVD's for my Pro4, but they are about 2mm shorter than my alu stock ones. This means that my outdrives pop out slightly when racing.
Is this a problem-can i damage/break anything? Can anyone offer some advice please i would be really grateful.
Thanks!
Andysan is offline   Reply With Quote
Old 10-10-2007, 07:02 AM   #15422
mangoman's Avatar
Hot Bodies Cyclone
Titanium diff screws, i wonder what they are like
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-10-2007, 08:39 AM   #15423
Trader Rating: 17 (100%+)
the associated diff screw conversion is still stronger
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 10-10-2007, 09:22 AM   #15424
bxpitbull's Avatar
You are 100% correct. The associated dff screw set is stronger and lasts for like ever.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 10-10-2007, 06:03 PM   #15425
acko's Avatar
Originally Posted by Andysan View Post
Hi all,
Thanks!
it sounds like you might hve cyclone ones as there is a very slight lenghth difference between the 2
TEAM TRASH TALK TOURING
losi mini baja/ sidewinder brushless on 3s li-po
losi xxxt mf2/ speed passion brushless 4.5 + li-po
pti goliath crawler... (always being modified)
hpi baja 5b ss 29.5 cc setting up 4 1/4 scale speedway
acko is offline   Reply With Quote
Old 10-11-2007, 05:51 AM   #15426
Andysan's Avatar
Exclamation
Hi,
Thanks for your reply. I've put some o-rings in the front outdrives to stop them from sliding around, would this be sufficient do you think? What worries me is that could i damage the outdrives by using these bones as they are shorter bones than the HPI allu ones i have removed?
I probably dont need and o-rings in the back because the outdrives are fixed to the diff and cannot fall out but i think i may do anyway.
Thanks, hopefully i'll be OK for my meeting on Friday.
Old 10-12-2007, 12:53 AM   #15427
acko's Avatar
i myself wouldn t use them as the conact area on the out drive will be right at the end of the outdrive. this may cause the very ends of the out drives to snap off. but anyways best of luck
Old 10-12-2007, 06:48 PM   #15428
bxpitbull's Avatar
Acko, your signature RULEZ!!!!!
Old 10-12-2007, 07:20 PM   #15429
acko's Avatar
yeah thats our crew. the trash talk boys
Old 10-12-2007, 07:30 PM   #15430
acko's Avatar
oopppsss.....
double post
heres the link to me avatar if ya interested
heres the link to the real size one
http://www.burnoutphotos.com/Burnout...playPhoto.aspx
Old 10-23-2007, 06:05 PM   #15431
TeckLancer's Avatar
Trader Rating: 16 (100%+)
hpi pro 4 still RULES !!!
TeckLancer is offline   Reply With Quote
Old 10-23-2007, 06:24 PM   #15432
acko's Avatar
yeah i still race 1. i swear by it
Old 10-24-2007, 08:40 AM   #15433
ROV
ROV's Avatar
Yer there great if you cant get a cyclone. or get with the times...ha ha
do you see ford v8 supercars racing a 2000 model......not...
the secret to bevels is shimms. or get belts, yer there always breaking teeth off,,how many bevels you been through acko...yer go on take your shoes off..
TELL THEM ROV'S HERE AND HE'S RUNNIN WHEELS THAT ARE READY TO RACE !!!
CEO TRASH TALK TOURING HOME OF WA'S CHEAP TRASH PISSTAKES
AM PSYCLONE,HOTBODIES D4,NOVAK,LRP,HACKER,MEGA,EFLIGHT.JR,KOPRO,HITECH, SPEKTRUM,TRAKPOWER,OS,CDC,SWASHDRIVE JET,ZENOHA,WEMOTECH DUCTED,LIPO4GO,LOSI,KOKOM,CDC,5IVE,8IGHT,XXCR,LST,CASTLE
ROV is offline   Reply With Quote
Old 10-25-2007, 05:50 AM   #15434
acko's Avatar
......roll up the sleaves......
so what are ya tryin to say there rovmiester. you sayin the cyclone consistantly beats the pro4?
are you a experinanced racer with the pro4.i neverr knew that shim trick i must have to try it some time
mabey everyone down the track must be sh%t if my pro 4 still kicks ass
your mud................
Old 10-25-2007, 07:31 AM   #15435
ROV
ROV's Avatar
Yes thats true............................in 540.running an ilegal 540.(*nose to nose)i like your avitar
latter sk8ter
