Like Tree5Likes
Old 02-17-2004, 09:26 PM   #1516
rc-zombies's Avatar
Originally posted by DJ_GenR8
rc-zombies...are you selling that cuda in your pix link, or is it already gone? Just curious...
sold over the weekend for an enormouse amount of $$$$$$
Old 02-17-2004, 11:08 PM   #1517
SpeedTech's Avatar
Hi Guys,
just want to give you guys a heads up, the Tobee Craft HPI Pro4 hop-up parts should be arriving next week. I'll have them up on the website soon.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 02-18-2004, 06:47 AM   #1518
Acer racing sells ceramic nitride ball bearings. I used the parts sheet to buy everything I need to hop up the kit, sans the steering assembly.
jleibund
jleibund is offline   Reply With Quote
Old 02-18-2004, 06:57 AM   #1519
trueracefan's Avatar
Send a message via AIM to trueracefan
rainbow 10's out of ball diffs, is there any other place to get parts for the pro 4?
trueracefan is offline   Reply With Quote
Old 02-18-2004, 07:01 AM   #1520
coastaltony's Avatar
Steve Wang
Send me an email when the Pro 4 hop-up parts arive. I am building three cars.
coastaltony is offline   Reply With Quote
Old 02-18-2004, 07:03 AM   #1521
Speed Demon's Avatar
Originally posted by Downforce
How is the access to the motor screws in relation to the EVO III. On an angle or a straight shot with your wrench?
If you're using the ball type allen key, you should be able to access it angles or straight...
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 02-18-2004, 09:48 AM   #1522
So if i'm going to race stock, the stock kit springs will do the job? And if I want to try diff. springs, should I get AE springs(congo) or Xray springs? or what? What's the consesus on the springs for this car, since we can't get HPI springs yet.
racingdc9 is offline   Reply With Quote
Old 02-18-2004, 10:00 AM   #1523
rc-zombies's Avatar
The stock springs should do fine for stock...I've also read HPI drivers using Rayspeed springs in their set-ups. mainly red's and white or white all around.
HPI:
Gold: 340 gF/mm
Silver: 302 gF/mm
RS
Gray: 355.69
Red: 326.37
White: 306.89
Yellow: 265.78
Old 02-18-2004, 01:12 PM   #1524
lazyboy's Avatar
Send a message via AIM to lazyboy
Post
how much is a pro4 soppost to run for in the us??
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 02-18-2004, 01:14 PM   #1525
rc-zombies's Avatar
$290 at Speedtech
$440 at Tower
Old 02-18-2004, 01:24 PM   #1526
RCBuddha's Avatar
Trader Rating: 33 (100%+)
I just paid $284.95 @ Ultimate....literally, about two hours ago on my lunch break!
Now, if i only had time to build it....
Buddha
RCBuddha is offline   Reply With Quote
Old 02-18-2004, 01:24 PM   #1527
robk's Avatar
Trader Rating: 22 (100%+)
"actually no...
front and rear toe blocks are identical. front has 2.5 of toe and 3.0 in the rear. the inside blocks are identical f/r but have different mount points than the toe-in blocks. you'll need the 0deg. blocks.. if you download the manual...you'll see why.."
Ok, now you have confused me even more... the manual shows 75144a/b and 75144 c/d as having a differing hole arrangement, then proceeds to tell you to stack a 75144a on a 75144c on page 8 right next to their note!?!? Probably an error, but basically you're saying the hole pattern is different on the f/r mount vs. the numbered toe in mounts (3.0, 2.5, etc.). Since that is a bust maybe another car's hubs could be used if they have toe in.. Kyosho rear hubs are similar, and I think they use 5x10mm bearings. Yokomos use 6x10s, so they are out.
I'm only bringing all this up because the carpet nats are in a month and 3* of toe will be slow
Old 02-18-2004, 01:30 PM   #1528
rc-zombies's Avatar
Originally posted by robk
"actually no...
the hole pattern on the F/R mounts differ from the toe-in blocks that are used. the toe-in blocks are interchangable and can be used in both the front and rear.
Old 02-18-2004, 01:39 PM   #1529
David Joor's Avatar
R/C Tech Charter Subscriber
Maybe a losi hub with a TC3 axle to the HPI bone and use a TC3 clamping hub
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 02-18-2004, 01:45 PM   #1530
Hinge pins are different, I think.
Downforce is offline   Reply With Quote
