Like Tree5Likes
Old 02-17-2004, 11:45 AM   #1501
V12
V12's Avatar
Originally posted by David Joor
Ahha, thanks for the tip. Do you know if you can run losi rear hubs on the car for the time being? I appreciate your help.
I donīt think so as Losi uses inch size bearings and HPI uses metric size bearings.
V12 is offline   Reply With Quote
Old 02-17-2004, 11:45 AM   #1502
David Joor's Avatar
R/C Tech Charter Subscriber
rc-zombies - Cool, it is something we do on the AE car, since Losi hubs are same geometry but have more adjustments and you can change toe with them because they come in 0, 1/2, and 1 degrees.
v12 - OMG, I should just stop typing, I feel dumb, good point
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 02-17-2004, 11:49 AM   #1503
rc-zombies's Avatar
I know what you mean...I've used the Losi rear hubs when I had my TC3 some 20 years ago...
With the Pro4 it's easier and faster to change toe-in blocks than the hubs..
Old 02-17-2004, 12:03 PM   #1504
TeamPRP's Avatar
Hey guys, I have this kit coming in soon. What part were you guys refering to exactly that has broken up front. You mentioned something about the instruction showing you to remove a small piece of material and perhaps this part should just be left on??? Any pics?
Thanks!
Ben
TeamPRP is offline   Reply With Quote
Old 02-17-2004, 12:39 PM   #1505
rc-zombies's Avatar
The part that holds the upper camber links...don't cut anything off of it...
Old 02-17-2004, 01:02 PM   #1506
corallyman's Avatar
Trader Rating: 99 (100%+)
Default Pro 4 owners
Does anyone know if any U.S. hobby shops have any repacement parts for the car yet, I know very few places have the kits yet, but did any of the parts make it onto the market before the kits?
corallyman is offline   Reply With Quote
Old 02-17-2004, 01:08 PM   #1507
rc-zombies's Avatar
Default Re: Pro 4 owners
haven't seen any replacement parts yet...Tower has them listed already. What parts you looking for? I might have some...
Old 02-17-2004, 01:16 PM   #1508
corallyman's Avatar
Default rc-zombies
Thanks for quick reply, but I was just wondering if parts are out there yet in case I decide to pull the trigger on buying the pro 4. It really interests me but as of now I am still running my other car (Corally Assassin). Barry Baker and Todd Hodge are coming up to our track(Seattle) in a couple of weeks and if I was to switch cars, I would want to have replacement parts for it. Thanks for your offer though.
Steve
P.S. have you driven your car yet? Do you ever run on carpet?
Old 02-17-2004, 01:19 PM   #1509
rc-zombies's Avatar
yes.. I've driven it...practive laps and tuning but no races yet...the weather hasn't been cooperating lately.
the car has alot of steering and plenty of corner speed. Haven't had a chance to run carpet yet...hard to get away with a 2yo son keeping me busy.....
if you ever switch cars...I've got several sets of arms, front knuckle/rear hubs, diff gears etc...
Old 02-17-2004, 01:21 PM   #1510
robk's Avatar
Trader Rating: 22 (100%+)
"rc-zombies - they have the stock pivot blocks that I put in bold which are 2.5 and 3 degree, I am looking for 0, 1, 1.5, and 2.0 degree blocks
75161 - Pivot Block 0 degree
75158 - Pivot Block 1 degree
75159 - Pivot Block 1.5 degree
75160 - Pivot Block 2.0 degree "
When the tc3 first came out, we used to use the f block in the rear in the place of the r to reduce toe in. You did have to add washers to bring back the correct anti-squat, but it was effective till the parts were out. I don't have the car yet, but maybe something along those lines could be tried. Even if you wound up with 0 toe, that might work for high traction foam tire racing.
Old 02-17-2004, 01:22 PM   #1511
corallyman's Avatar
Thanks Zombies I let you know.
Steve
Old 02-17-2004, 01:31 PM   #1512
rc-zombies's Avatar
actually no...
front and rear toe blocks are identical. front has 2.5 of toe and 3.0 in the rear. the inside blocks are identical f/r but have different mount points than the toe-in blocks. you'll need the 0deg. blocks.. if you download the manual...you'll see why..
Old 02-17-2004, 04:52 PM   #1513
How is the access to the motor screws in relation to the EVO III. On an angle or a straight shot with your wrench?
Downforce is offline   Reply With Quote
Old 02-17-2004, 05:59 PM   #1514
snoopy's Avatar
Default Re: Chassis middle brace
Originally posted by chr15tophe
I see in the pics of the pro4 on the hpi website there is a centre brace for the top deck, in the instructions it doesnt pay mention to this, but is included in the kit, is anyone using this?? is it there just as a optional part to stiffen the chassis if the user requires extra stiffness?? or are people leaving it off???
I've run mine on carpet and use the middle brace. it definitely makes the chassis stiffer and more reactive.
snoopy is offline   Reply With Quote
Old 02-17-2004, 07:22 PM   #1515
DJ_GenR8's Avatar
rc-zombies...are you selling that cuda in your pix link, or is it already gone? Just curious...
DJ_GenR8 is offline   Reply With Quote
