Old 03-13-2007, 03:14 PM   #15016
trjracing's Avatar
I don't have a PRO4 yet but it is similar to the TC3 and I had too shim up my diffs too. If you have diff shims use them, you will get a better gear mesh. Shim the side of the diff that holds the diff gear(The shorter side), and you should be good to go... GOOD LUCK...
trjracing is offline   Reply With Quote
Old 03-13-2007, 03:19 PM   #15017
mangoman's Avatar
You should soak the bevel gears in hot water before installing (which is something stated on the hpi site somewhere). That helps to stop them from shattering teeth but yeah shimming of the gears is very important.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 03-13-2007, 03:23 PM   #15018
trjracing's Avatar
Yes, you can boil the gears for 15 minutes in hot water and what it does it makes the plastic flex under load, It becomes flexable... It works thats a old but good trick... I'm with you on that one...
Old 03-13-2007, 03:29 PM   #15019
mangoman's Avatar
One other thing you could try is to get a p-dub bumper. They are stiffer and wider than normal bumpers and as a result they give more protection to the suspension parts.
The bevel gear usually gets smashed up when you run a spool or one-way and when you tag things it puts a lot of stress on the front drive train. The wider bumper might help to prevent that but i dont know....
www.smaracing.org
Old 03-13-2007, 03:31 PM   #15020
trjracing's Avatar
That will work too, I'm with you on that one too...
Old 03-13-2007, 04:00 PM   #15021
bxpitbull's Avatar
Originally Posted by minnesh
gentlemen it was a crash the second time out and then clunk..clunk
and i was told that it could be the front diff gear ,after the heat i stripped it and the plastic gear (one that fits onto the shaft) was misssing three teeth
managed to buy another at the track got it in, car ran however is sounding rough. any suggestions ,guys are talking of shimming the gear for a good mesh
any advise on how and why this sould be done
thanks
minnesh
Look up sleepy23, he has the molds for aluminum outdrives for the Pro4. Cheap. Like 32 for the car.I bought to sets and havent ruined a diff since!
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 03-13-2007, 04:03 PM   #15022
bxpitbull's Avatar
Default TRJ....is a BUM!
Thats right I said it. He is a bum, straight out of skidrow. He's got you people fooled! Just kidding. Listen to the dude. Especially you cats that are still running brushed motors (brushes are for hair). The dude knows what he is saying. I hope he is paying attention to what he writes. Yo J, Friday, chinese food and a really good smacking!
Old 03-13-2007, 05:04 PM   #15023
trjracing's Avatar
Bx Pit yous a funny dude, you lucky you my best friend, Sounds good for friday I'm down for that and we need to set up our race so I can hurry up and beat your million dollar slow4 Just foolin... Later Bro...
Old 03-13-2007, 05:06 PM   #15024
trjracing's Avatar
SLOW4
Old 03-13-2007, 05:10 PM   #15025
trjracing's Avatar
Bx Pit, we need to test your car before sunday, they are talkin rain on friday, we set up your Pro4 and I guess test it on sat. Or if its dry fri. nite we make some test passes... And find the gearing where your car is comfortable at!!! Later Bx Pitbull.
Old 03-13-2007, 05:14 PM   #15026
trjracing's Avatar
You still ain't gonna beat me, your car is fast but it doesn't have what it takes to beat me. I hate to break the news to you but Bx Pitbull you gonna lose...
Old 03-13-2007, 05:24 PM   #15027
trjracing's Avatar
Hey Bx did you set up the pro3 too???
Old 03-13-2007, 06:58 PM   #15028
trjracing's Avatar
Oh, Bxpitbull don't let the big tire 68 camaro scare you, you ain't ready to race my big tire monster, Don't get scared of the picture Bxpitbull.
Old 03-13-2007, 07:01 PM   #15029
trjracing's Avatar
Yes, the green camaro you see is 14cells...
Old 03-13-2007, 07:06 PM   #15030
trjracing's Avatar
Well Bx Pitbull you know this car you seen it too many times, So when you get the smack talkin just look over at the Green Beast and then fall back and play your position... Hold That!!! You don't want none of the 68 Camaro. Or like you say, (YOU DON'T WANT NO PROBLEMS!!!)
SEO by vBSEO 3.5.0
