Old 10-04-2007, 05:20 AM   #16
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Renuco612, give it a try and see what happens.
I would say use the setup sheets as a guide because 99% of the time you cannot duplicate the traction, layout, track size, etc at your track.
Kraig is offline   Reply With Quote
Old 10-04-2007, 01:39 PM   #17
Renuco612, If you race on a large track it might be helpfull however the guys at my local track that run rubber tire on carpet dont use them.....I have ran rubber tire on asphalt and used a oneway but liked the spool better....If this is your first T/C listen to 51 and ask around at your track.....But if your track leaves it lap timing sys. on or a buddy w/ a stop watch can determine this for you.....The setups from AE are a good starting point but guys drive and like there cars to act and feel differently.....The only way to get faster is to try new things but with T/C ONLY TRY ONE THING AT A TIME and document your changes along with track conditions...
NUCRPTRACER is offline   Reply With Quote
Old 10-05-2007, 07:57 PM   #18
Victory Side's Avatar
Send a message via Skype™ to Victory Side
Thanks for all the help. I switched the springs and that did help. I also decreased my servo end point and spped. That helped, but this week I want to take the shims out. Hopefully this will help some. There are not to many experienced guys. We are a new track. We went out and bought the transponder system and got a gym that is carpeted with a great track. I am just trying to figure this thing out. It probly is more car than I need, but I hope to grow into it and I love the car. I will let you know what the shims do. After that I will let you know, and see if I got it dialed in.
Victory Side is offline   Reply With Quote
Loose Change D Hunt 3 Chat Lounge 0 09-01-2007 07:41 PM
to loose dozer1160 Onroad Nitro Engine Zone 2 04-20-2007 05:41 PM
Loose HSN help willjeffw Racing Forum 1 06-19-2006 09:03 PM
Loose driveshafts DrMartin Electric Off-Road 0 08-28-2005 04:51 AM
gear loose? 92tsiawd84 Rookie Zone 4 08-24-2003 10:22 AM
SEO by vBSEO 3.5.0
