SpeedMerchant Rev 5
#151
#152
If your patient, and can wait.. you'll have a nice 1/12th car. If not, then there are plently of 12L/ Rev 4 copy's out there to choose from.
Whats your name anyways???
#153
Sorry Jeff,
Only what i had heard... thats why I said it was a rumor.
#155
How about a head count of those who've paid for a Rev 5.0 directly from Speedmerchant and have not recieved it.
I'm going on 8 weeks and know of 3 others in the same boat.
#156
#157
where can i order parts for the rev 5 since teamspeedmerchant.com doesnt have them on there site
#158
Guys,
I hate to break it to you but you probaly won't get your Rev 5 before then end of the season. If you can get a hold of someone over there just ask for your money back...
There are plenty of other cars with good support behind them to choose from.
Good luck,
Travis
Good luck,
Travis
#159
they didnt ship yet?! I thought some of the people have the cars already, or is that just the front end that they put on the Rev 4?
#160
i already have my rev 5 i just need some bushings for the front end cuz they were out pretty easy so i was wondering if there is anywhere else i could order them from
#161
They have the teflon bushings, AND AWESOME service, I've picked up 2 rev 5 at different times as well as a parts order. All shipped the same or next day.
#162
anyone have setups for low or medium traction anyone know where you can get mike dumas setups
#163
Front:
Jaco Lilac (on prism rims) start at 1.65" diameter
.020 springs no preload
-1 degree camber, 3 degrees caster
inner ball ends second hole from the center of car (middle hole) front and rear
ride height 3.5mm
drop of light spooge or Corally medium dampener syrup on kingpin
Rear:
Jaco Yellow (on Prism rims) start at 1.75" diameter
.023 side springs no preload, just touching
SpeedMerchant Blue spooge in the tubes
red shock spring, 40wt oil in shock (IRS TopGun shock)
Ride height 3.5-3.75 mm
Pod droop 1mm gap at hingeline with shock at full extension
pod droop .5mm race ready without body
Body Parma Speed8 for stock, Speed8HD for 19 turn
Very nice for stock and 19turn at 360Speedway
ride height 3.5mm
Rear:
#164
Use red spooge on the tubes for lower traction.
#165
Looking at the new front end on the team speedmerchant website, I did not find the new front end kit listed in their on-line shopping menu.....
Did I miss it?
THX
Did I miss it?
THX
