Old 05-13-2003, 04:55 PM   #1
doublest's Avatar
Send a message via MSN to doublest
Is this true?
Is it true that with Sanyo 3000H cells u dont have to discharge after each race, that u can just charge back up, and that can be done no more than 3 times to keep them in good order. Aparently they get better as u charge without discharging for those 3 times. Then after the third time u discharge and put charge into them forr storing.
doublest is offline   Reply With Quote
Old 05-13-2003, 06:57 PM   #2
popsracer's Avatar
Default Charging/Discharging NiMh Batt's
As long as you allow time for cooling you can charge NiMh's more than once a day. For storage, leave a partial charge in the pack. Discharge the night before and your ready on race day for charging.
popsracer is offline   Reply With Quote
Old 05-13-2003, 08:06 PM   #3
im pretty sure if you do a search using the search feature you will find answers to alot of your questions instead of making up new threads for every question you have...
Jarrod Langlois is offline   Reply With Quote
Old 05-14-2003, 03:12 AM   #4
doublest's Avatar
I searchef for the answer, but couldnt find if i was really allowed to charge more than once in the same day, without discharging in between.
Im told up to 3 times without discharge?
Old 05-14-2003, 03:42 AM   #5
fasterdanu's Avatar
i cant reccomend itnot as good as getting a full fresh charge
fasterdanu is offline   Reply With Quote
Old 05-14-2003, 04:44 AM   #6
Cole Trickle's Avatar
You probably wont get an "yes or no" answer on this.
But even though they claim that NiMh dont suffer from "memory" problems, they do. However, I cant tell if 3 times partial charge followed by a full discharge/charge before the next race, will matter much.
Personally I think you'll get the best track-performance by discharging to 5,6 volt between each charge. However, I dont the equipment to measure wethever it's true. Maybe this routine will shorten life a little, but again, I aint got the equipment and time to prove it.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 05-14-2003, 08:24 AM   #7
shrekair's Avatar
Trader Rating: 9 (91%+)
I second the quit start a ton of new threads. with less then 15 minutes or searching i found the following threads about batteries that relate:
Discharging Ni-Mh
THE batteries for stock/light mod
Who makes the right GP 3300 batt. bar?
3300s now 2800s
Nimh Care questions (NEED HELP!!!!!!)
these are threads about batteries you already started!!!! use them!
What to do with new batteries??
New to RC, what batteries??
shrekair is offline   Reply With Quote
Old 05-14-2003, 08:35 AM   #8
Elk666's Avatar
I bought my battery packs from my lhs wich is also a battery supplier for some team drivers, the company is called Pole Position, the owner said to keep packs in good working order, do as follow: charge your pack just b4 running them, once your done racing discharge your pack and let cool down at least 2.5 to 3 hours time.
so far i've followed his instructions and my 4 packs (3000 sanyo's HV) are working flawlessly they peak above 3000mah everytime and give me a good 10-12min on a novak brushless system on unlimited setting.
hope this helps
Elk666 is offline   Reply With Quote
Much-More TRUE BALANCE rcforum Electric Off-Road 13 08-17-2010 07:24 AM
true tires mrrcguy Electric On-Road 12 06-02-2010 11:13 AM
to true or not to true tyres on club days ?? mrgsr Nitro On-Road 4 08-11-2005 05:11 AM
Is This True???????? Zac R Electric On-Road 24 03-24-2005 08:47 PM
Is this true ?????? Brett Australian Racing 9 07-14-2002 01:33 AM
SEO by vBSEO 3.5.0
