Old 09-14-2007, 02:32 PM   #1
Default TT01 Mechanical Speed Controller Question
Im a newbie so bare with me!
Got an old TT01 with a mechanical speed controller. How do these wire up to the servos?
Got battery, steering servo, wired to receiver but cant figure out how the other servo works with the msp. What am I missing? Should I just buy a electronic SC?
A quick pic from someone will prob do the trick.
kimera is offline   Reply With Quote
Old 09-14-2007, 02:35 PM   #2
PS Its a Acoms 2 Channel Radio Set with 2 Servos Im trying to use
Old 09-15-2007, 07:51 AM   #3
Johnathan's Avatar
you plug the 2nd servo into the throttle channel of your reciever. you then should have the servo mounted to the msc. so heres how all of it should be:
-both servo's are connected to the reciever, in thier proper channels.
-the battery will conect to the msc, but dont connect it until everything else is set.
-there will be power wires that go to the reciever. plug it into the battery slot/"channel".
- make sure the resistors are properly hooked up, they're the white ceramic things.
- make sure you have the motor hooked up.
try it out. hook up the battery, and turn it on: it should work. if for some reason it does not, Imediatly take the battery out. a mislocated wire may cause damage to other electronics.
i hope that helps!
Johnathan is offline   Reply With Quote
Tamiya mechanical speed controls ctimm R/C Items: Wanted to Buy 3 03-06-2008 07:48 PM
mechanical speed controller Wreckless_Daz Electric On-Road 4 08-22-2007 01:11 AM
Tamiya 3-step mechanical speed controls minimadman2003 R/C Items: For Sale/Trade 2 08-08-2007 04:17 PM
WTB: Cheap mechanical speed control kuzo R/C Items: Wanted to Buy 2 08-21-2006 05:50 PM
Speed Controller QUestion miniczar Electric On-Road 8 02-21-2006 11:02 AM
SEO by vBSEO 3.5.0
