Old 09-13-2007, 05:27 PM   #1
Default esc question
i have a brand new lrp brushless tc esc, when i turn the system on the motor runs for a few minutesthan stops. is this a programing issue? if it is which setting should i look at? thanks for the help.
chrisw is offline   Reply With Quote
Old 09-13-2007, 06:16 PM   #2
Mooshu Beef's Avatar
Your battery sounds like it is either not high enough mAh (affects current) or just way too old.
I know LiPo setups demand high current batteries that come with high mAh ratings. How old are the batteries, and how's the mAh? If it's running for a few minutes then stopping I believe that the mAh is just way too low, or your charger has some issues.
The Built in BEC will cut off the voltage after the voltage drops below a rating.
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 09-13-2007, 07:26 PM   #3
Sneaky Pete's Avatar
The default battery profile is set to Auto Lipo. If you are running NiMH's, change the battery profile to #2 instead. Hope this helps!
Sneaky Pete is offline   Reply With Quote
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 08:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 05:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 08:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 11:46 AM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 09:33 AM
SEO by vBSEO 3.5.0
