Old 12-06-2001, 06:13 PM   #1
carpet_killa's Avatar
Default does anybody use digital scales for a tweek station???
i bought a couple of mini scales at a good deal and i have seen that team irs uses digital scales as a tweek setup. so i am tring to figure out if and how ot do this for a 12 scale car carpetknife. if any of you use this or have a picture of this kind of set up i would appreciate the info...
carpet_killa is offline   Reply With Quote
Old 12-06-2001, 06:29 PM   #2
MissX's Avatar
I have used a digital scale to measure the tweak. You need at least 2 scales. 4 would be perfect. Make sure they are on an even platform, reset the scales to zero and just place your car.
You can see the weight distribution there. Adjust the collar on the shock to achieve the best possible even weight distribution. It's hard to get perfect,but at least you are getting the best. Sorry I don't have the picts with me. Perhaps you can visit team IRS.
MissX is offline   Reply With Quote
Old 12-06-2001, 06:42 PM   #3
Default reply
the thing is is that i don't have spring collers on the 1/12 scale like there is on a tc3 or 10 scale with threaded shocks. so i guess i need to use 4 scales on a flat surface for tweeking instead of just 2.
Old 12-06-2001, 07:10 PM   #4
Peter Busch's Avatar
R/C Tech Charter Subscriber
I have 4 scales for tweaking. You need to make sure the surface you set them on is level. For 12th scale I pretty much only use two of them under the back axle. To adjust the tweak out you need to move the side springs up or down, just make sure there is no preload on the springs and that they are just barely touching the metal ball. If one of your front suspension springs is smashed down more then the other it will affect the tweak also. You need to keep the front two sides the same.
Peter Busch is offline   Reply With Quote
Speedmind tweek station snopro31 R/C Items: For Sale/Trade 10 10-27-2007 06:35 AM
Setup station/break-in-bench/tweek station/setup-board rcfoolz R/C Items: For Sale/Trade 7 07-16-2007 11:19 AM
MIP Tweek station for sale crazymechmow R/C Items: For Sale/Trade 15 01-26-2006 12:46 PM
MIP tweek station picco007 R/C Items: For Sale/Trade 9 10-13-2004 07:36 PM
FS: Integy Setup Station and MIP Tweek Tres R/C Items: For Sale/Trade 5 03-15-2004 10:32 AM
SEO by vBSEO 3.5.0
