Old 02-07-2008, 04:15 PM   #1291
POUNDITRACING's Avatar
I'm getting a 416. What else do I need to get? I want to run a spool.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 02-07-2008, 07:51 PM   #1292
Stein Tumert's Avatar
Jaad spool http://www.racingfactory.fi/shop2/ca...ils.php?p=1765
Short EVO5 arms
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 02-07-2008, 10:29 PM   #1293
sakaguchinet's Avatar
Send a message via ICQ to sakaguchinet Send a message via AIM to sakaguchinet Send a message via Skype™ to sakaguchinet
Hi,
the MRE Spool will be similarly priced (here in germany) as the one from jaad.
Tamiya should now show the 44mm MIP-CVD Driveshafts (available from Steel, Titanium and Aluminum). I am not really happy with the 42/46mm swing shafts.
A new black spring set would be also very interesting. On the Tamiya Fair in November I can remember there was something like this shown.
Square will release in a few days the hard anodized blue aluminum c-hubs with 4° of caster.
As diff covers I use the following solution: Take a decal sheet (I love the LRP ones *gg*) - take a ("Schneidzirkel") ... something like cutting compass - ready! For those who are too lazy: Tamiya #53980
sakaguchinet is offline   Reply With Quote
Old 02-08-2008, 01:01 AM   #1294
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Smile Should be fun Ed
Originally Posted by TryHard View Post
Especially so as I'll be racing 5 cell/brushless modified for the first time in a few weeks at the Carpet Wars two day... fully expecting to make a bit of a fool of myself, but hey, at least I'll have fun
Ed
Ed just get the Ta05 outdrives for your spool as the only thing I have broken in 5 cell mod is th spool outdrives in 2 years of racing mod with the the 415. Running the plastic ones at the last carpet wars caused me 4 DNFs just through clipping the bot dots
HTH
Mark
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Old 02-08-2008, 01:08 AM   #1295
Mitch P. is offline   Reply With Quote
Old 02-08-2008, 02:38 AM   #1296
Send a message via AIM to canto54
Originally Posted by Stein Tumert View Post
this is not a JAAD spool
canto54 is offline   Reply With Quote
Old 02-08-2008, 03:46 AM   #1297
TryHard's Avatar
HTH
Mark
Cheers Mark,
I'm really looking forward to it, shoudl be a lot of fun. Good thing I know just to drive within the limits of the car to begin with, get round without mistakes, and I'll probably end up with a decent time
I'm only going to be using a 4.5.... a 3.5 will be a waste imo, as I won't be able to make most use of all the power... and having said that, a number of A finalists are using 4.5's as well... too much power can be a bad thing
I've invested in some new cells too (IB46), so runtime won't be an issue... I hope
I don't know why, but I think I'm going to feel bored at the next round in stock... it's too slooooooooooooooooow
If your there on the 17th come say Hi, I'll be easy to spot, pretty much all blue pit area (I know, I'm a blue biatch )
Regards
Ed
Old 02-08-2008, 09:02 AM   #1298
Smile
Hi Ed
What make of motors will you be using I use GM. It really depends on the layout at carpet wars. If it is one of the flowing layouts a 3.5 will be fine however that said the last one I was at I think that it would have been difficult getting a stock round due to how tight it was.
See you There
Mark
Yokomo BD
CEFX C12
Mark Ashby
Old 02-08-2008, 09:13 AM   #1299
RC MARKET's Avatar
the outside cup too soft !
RC MARKET is offline   Reply With Quote
Old 02-08-2008, 09:55 AM   #1300
kentech's Avatar
I run the JP Spool on my 415 for months and months with no significant wear, and the TRF416 versíon is even better. To say the cups are too soft is just BS.
This is one of the best quality RC products I have seen in my 18 years in this hobby, and ask anyone who has seen it and they will say something similar...
This links to the JP Spool. There's no TRF416 spool available from JAAD yet.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 02-08-2008, 11:17 AM   #1301
AWK
AWK's Avatar
Tamiya's 416 spool will arrive early April as will the center one way. Parts are 49493 and 49492 respectively.
AWK is offline   Reply With Quote
Old 02-08-2008, 11:52 AM   #1302
Trader Rating: 45 (100%+)
Who distributes the JP Spool in the U.S.?
Apex is offline   Reply With Quote
Old 02-09-2008, 07:44 AM   #1303
JimmyMac's Avatar
If anyone is interested, I posted pics of my car with the Ez-Lipo plate here PPD EZ-LiPo --TC5 and beyond LiPo mounting Solution.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 02-09-2008, 08:49 AM   #1304
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
jimmy,
what charger are you using to maintain your lipo packs btw?
Yo!
KoE is offline   Reply With Quote
Old 02-09-2008, 09:59 AM   #1305
bboy's Avatar
Originally Posted by rough512 View Post
BBoy :
A bit late but try it anyway. Use a pinion gear 1 teeth bigger that the one you're intending to use. Mesh it snugly at the tightest spot with your spur gear (remember, no spur/pinion gear is perfectly round, there is always a spot that appears notchy). Then take out the big pinion gear and install the correct-teeth gear.
Alright ... I figured out why I keep loosing teeth on my Spur. I run LRP 3.5 brushless and according to manual, I try to set a gear ratio of 10.5+ (my local track is fairly small) so with a 105T Spur, I used a 21T pinion, and I finally realized that because the pinion is so small, I could not get a close enough mesh because I have already pushed the mesh as far as I could and the motor mount just wouldn't let me get closer!
Oh well, I am now off to the stores to pick up a 120T to see if that will help. I also talked to some guys at the track and they suggested that one way to set mesh is to hold the pinion steady, rotate the spur, and the spur should move just very little. Too much will mean it's too loose.
So much for my weekend run ... sob.
bboy is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
