Old 02-05-2008, 01:06 PM   #1261
TryHard's Avatar
hey guys... got the setups section working on my site now.
If anyone has any setups they'd like added on there, let me know
TRF416 setups
regards
Ed
Old 02-05-2008, 01:11 PM   #1262
Nathan Parker's Avatar
Originally Posted by TryHard View Post
Hey Mark,
Yeah, the 415 ones fit fine, hell the hole 415 suspension will fit. However, if you want to keep the suspension as close as possible to the 416, use HPI front hubs as well. If you use a 416 steering knuckle in the 415 c-hub, the axle will be 1mm higher, and this affects roll center and droop, among other things...also the steering links will be in a slightly different position. Using the HPI knuckle and 415 c-hub keeps it fairly close to the 416 geometry.
HiH
Ed
Hmm not according to my measurements
Other than a little filing of the 415 C hub it fits a treat.
Will have another measure thursday when I look at the car next
Nathan Parker is offline   Reply With Quote
Old 02-05-2008, 04:07 PM   #1263
TRF416 setups
regards
Ed
Look there, you have some others setups
Arn0 is offline   Reply With Quote
Old 02-05-2008, 04:33 PM   #1264
JimmyMac's Avatar
No need to file 415 chubs. They fit no problem. Just have to flip the bushings around and shim differently. I had to use a set of 2* blocks a couple weeks back because I broke all my left side 416 chubs.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 02-05-2008, 06:43 PM   #1265
Hi Guys,
Anyone Going to Bangkok for TITC?
Need some start-up setup for the 416 at RCS. What bodyshell would be suitable for the RCS track?
aztecz is offline   Reply With Quote
Old 02-05-2008, 07:10 PM   #1266
bboy's Avatar
Cool, thanks for the tips on the mesh. Let me try and report back to see if I can save a spur or two
bboy is offline   Reply With Quote
Old 02-05-2008, 07:15 PM   #1267
bboy's Avatar
Hey Ed,
Your site is SOOO COOLL!!! Wow thanks for sharing the information.
One question, regarding your block chart for toe in and toe out, what should the tierod lengths be to use the Front in-board toe table?
Thanks so much again!
Old 02-05-2008, 07:43 PM   #1268
bboy's Avatar
BTW how do you guys keep the rear diff clean? I am finding that I need to clean it after every meeting since the grease attracts a lot of dust and dirt. Is this normal?
Old 02-05-2008, 08:29 PM   #1269
rough512's Avatar
Default re: gear meshing
BBoy :
A bit late but try it anyway. Use a pinion gear 1 teeth bigger that the one you're intending to use. Mesh it snugly at the tightest spot with your spur gear (remember, no spur/pinion gear is perfectly round, there is always a spot that appears notchy). Then take out the big pinion gear and install the correct-teeth gear.
rough512 is offline   Reply With Quote
Old 02-05-2008, 10:18 PM   #1270
fadzli's Avatar
i use a black round (donut) sticker like that u can stick the each side of the diff to cover the opening. i think there are from tamiya. cant remember.
u can make urself one using any sticker and make a donut shape.
Do Not Follow Where The Path May Lead. Go Instead Where There Is No Path And Leave A Trail.
fadzli is offline   Reply With Quote
Old 02-05-2008, 11:34 PM   #1271
JimmyMac's Avatar
I do what Fadzli does. Except I use JAAD diff covers. I can take a pic if you need to see what I'm talking about. I also tape over the diff adjustment screw hole to keep dirt out of there too. Just remember to be careful when blowing off the car. Do not blow directly on the diff. Always try to aim away from it.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 02-05-2008, 11:36 PM   #1272
JimmyMac's Avatar
Originally Posted by aztecz View Post
Hi Guys,
I wish I was going. But I would start with kit setup. When you are there, talk with the Tamiya team. I'm sure they will guide you in the right direction. Are you racing Mod or 23t? Maybe you can take some pics for us!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 02-06-2008, 01:00 AM   #1273
TryHard's Avatar
Hey Ed,
Just set the tie-rods to the correct length for the required amount of out board toe. If your using wider blocks (such as D/D) you'll require longer links, and vice-versa.
I can't really tell you correct lengths for the required levels, as that will also vary with different amounts of ackerman spacers, and if you use a different hole on the hub.
HiH
Ed
Old 02-06-2008, 02:25 AM   #1274
asw7576's Avatar
Hi everyone
I'm not familiar with the term " Rebound Stroke " in Tamiya Setup Sheet.
Is Rebound Stroke = Downstop value in Hudy blocks ?
eg. 2mm rebound stroke = number 2 on Hudy block ??
Tks.
Old 02-06-2008, 05:29 AM   #1275
Stein Tumert's Avatar
Originally Posted by asw7576 View Post
Hi everyone
Tks.
My understanding is that this is about the shocks, rebound stroke is how much the shock comes out again after you push it all the way in and let go of it...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
