Old 01-21-2008, 04:24 AM   #1111
TryHard's Avatar
Originally Posted by Pijjetrf View Post
hi ed thanks for the info will have a look hope you did not mind me using your setup sheet
p.s have sent u a p.m
pm back at you
Old 01-21-2008, 06:11 AM   #1112
Trader Rating: 45 (100%+)
Originally Posted by Vicko View Post
so anyone tryed to fit the cyclone metal front C-hubs on the 416 yets?
or any other types of metal c-hubs?
I ordered some of these to try.
http://precisionrc.com/nv/car/produc...oduct_id=54170
I also ordered quite a few sets of the stock c-hubs too.
Apex is offline   Reply With Quote
Old 01-21-2008, 06:48 AM   #1113
RC MARKET's Avatar
Originally Posted by Kenneth Tan View Post
Fitting of stick packs:
arrived
Tamiya TRF416 / TRF416WE / TRF416X-ta-9114036.jpg
RC MARKET is offline   Reply With Quote
Old 01-21-2008, 03:29 PM   #1114
Originally Posted by Jilles View Post
Hello Guys,
Attached my set-up from DHI Cup last weekend.
Marc's set-up was same, Viktor only used 0.5mm rollcenter shims and front 0.5mm anti-dive.
Jilles
Jilles - What tire additive did you use? And how did you apply the additive to the tires. From some of the pictures it looks like you were just applying a stripe of additive down the middle of the rear tires?
Old 01-21-2008, 04:10 PM   #1115
Vicko's Avatar
Trader Rating: 14 (100%+)
I order those too
also order the cyclone type to try also
Vicko is offline   Reply With Quote
Old 01-21-2008, 10:11 PM   #1116
CLK@racing's Avatar
Dear moderators,
Just would like to request you to change this thread name to read: Tamiya TRF416
Thank you
Real man races Modified.. simple.
CLK@racing is offline   Reply With Quote
Old 01-21-2008, 10:18 PM   #1117
adamge's Avatar
Originally Posted by CLK@racing View Post
Dear moderators,
Thank you
... no joke
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 01-21-2008, 10:34 PM   #1118
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by adamge View Post
... no joke
Intruder alert! Don't you have a battery bar to flatten out? :-D
syndr0me is offline   Reply With Quote
Old 01-22-2008, 12:03 AM   #1119
bigbutstupid's Avatar
Does anyone know if the F part for tamiya (battery post) might fit the 416? it seems like it does. i dont really like shrinked wrap battery pack as i cant individually discharge the cells. and dont like battery tapes too.
bigbutstupid is offline   Reply With Quote
Old 01-22-2008, 02:44 AM   #1120
Send a message via MSN to jontang001
... no joke
Sorry, but I like "no joke"
Ya~~~TRF416 is not a joke!!!
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 01-22-2008, 12:24 PM   #1121
Customworksking's Avatar
Trader Rating: 69 (99%+)
Default 415,416
so what from my 415 can I use for the 416 a-arms ? I know the a,b,c,d blocks
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-22-2008, 12:55 PM   #1122
JimmyMac,
When building the shocks I adjust the rebound by lifting the shock piston up till a certain height. Then I check the rebound and make all for the same. Normally I use very little rebound so I move the piston all the way up and let the oil coming out as much as possible. Difficult to explain but try as much as you can and you will learn it.
Apex, I used CS high grip. Most drivers used it. Rear we applied full and 40 minutes before the run. Front 2/3 and 15 minutes before the run. The additive dryed out pretty soon so that's why it looks like we applied it in the middle.
The arms we used where the Evo5 arms.
Maybe I missed some question but feel free to ask again.
Anyone coming to the Snowbirds next week?
Jilles
Jilles is offline   Reply With Quote
Old 01-22-2008, 01:07 PM   #1123
TryHard's Avatar
JimmyMac,
Jilles
Hi Jilles,
Quick question regarding rebound. I set a full set of shocks up with minimal rebound. I did this by taking the the spring retainer, putting it on the shaft and then pressing the shaft up until the retainer was hard against the shock body... just an easy method to ensure the setting was the same. Checked them after setting, and all were achieving 4mm of rebound, at the same return rates.
Anyway, took the shocks off yesterday following a couple of runs on saturday night, and the amount of rebound seems to have gone up to 10mm+ now! is this normal? Or should I be checking for a leak somewhere (no oil leaks or trapped air was apparent in the shocks).
I'm not running anything above the bladder, so wonder if that was having an affect.
Good luck at the 'birds... bit of a long way to travel for me!
Ed
Last edited by TryHard; 01-23-2008 at 04:01 AM. Reason: making more sense... shocks with no oil, wtf?
Old 01-22-2008, 02:02 PM   #1124
JimmyMac's Avatar
Thank you Jilles. I have just started building my shocks this way. I will test it out this weekend.
I have been goin to the Snow birds for several years. But didn't go last year. And can't make it this year. Perhaps next year. Have fun out there. I will be looking forward to your results.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is online now   Reply With Quote
Old 01-22-2008, 02:27 PM   #1125
Can we get CS Electronic High Grip in the U.S.? I hate using Paragon. P.U.!!!
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
