Like Tree3Likes
Old 01-19-2008, 05:51 PM   #1081
JimmyMac's Avatar
I would not run a spool with foam tires on carpet. I would run a front diff.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-19-2008, 06:06 PM   #1082
justin lessard's Avatar
Send a message via AIM to justin lessard
A spool will make the car very difficult to drive with foams on carpet,the car will steer violently on power
justin lessard is offline   Reply With Quote
Old 01-19-2008, 06:54 PM   #1083
fadzli's Avatar
whta should be adjusted or added?
Do Not Follow Where The Path May Lead. Go Instead Where There Is No Path And Leave A Trail.
fadzli is offline   Reply With Quote
Old 01-19-2008, 08:52 PM   #1084
HI_808's Avatar
You can add spacers under the front rear suspension mount to add anti-dive. To add kick-up, use spacers under the front front suspension mount.
HI_808 is offline   Reply With Quote
Old 01-19-2008, 11:24 PM   #1085
fadzli's Avatar
Default rear toe in
i assembled everything as to manual. the problem is the rear toe angle is not the same. one is 3deg and the other almost 4deg. i think this is not adjustable. maybe the screw hole does not symetry. any suggestion? tq.
Old 01-19-2008, 11:27 PM   #1086
fadzli's Avatar
is this means that to change the suspension angle to front or to back?
Old 01-19-2008, 11:41 PM   #1087
bigbutstupid's Avatar
you are probably right fadzli, its the same for me as well for my rear toe angle, one is exaztly 3deg and the other is slightly more than 3... i think it was about 3.5deg. i yet to check it again after rebuilding my car but i have to wait for my spare parts to come in tmr first before being able to give you an answer.. but just to let you know, you're not the only one and perhaps others may be able to help you with the answer.
bigbutstupid is offline   Reply With Quote
Old 01-20-2008, 12:43 AM   #1088
fadzli's Avatar
have u drive ur car on track? what is the result?
Old 01-20-2008, 01:29 AM   #1089
mac853's Avatar
Originally Posted by moonman View Post
I tested the JP 416 spool today. http://www.racingfactory.fi/shop2/ca...ils.php?p=1765
Perfect fit, supernice finish and high quality delrin outdrives. With this spool the pulley is perfectly aligned with the axle centerline as opposed to the MR spool with the pulley flipped over.
I have a lot of questions for anybody to answer me then i will ordering my new kit for race of this year, please:
Instead of racing factory has release this 416 spool, i want to know have still more online shops to sell the same?
I want to use 2holes piston instead of 3, the ref. number of this part could be as the same of 415mre, tam53572?
If I want using slightly softer springs than original's blue/yellow, could changed by HPI silver/gold springs or more else, then i don't need to change the shock retainers of other brands?
Best regards
mac853 is offline   Reply With Quote
Old 01-20-2008, 02:20 AM   #1090
to be honest, i dont know. because i havent really tried to get the toe done right as i i cant without having new blocks to try on.
i dont think it will have a great effect on the car. even if it does, i wouldnt have notice as im not to a level of "pro"ness and im not that sensitive to 0.5deg difference in toe. but theres definately no tweaking or the tail of the car swivling left to right.. as i've mentioned in my previous post... i love this car and its awesome to drive.
Old 01-20-2008, 05:51 AM   #1091
fadzli's Avatar
Originally Posted by Markiempje View Post
well speaking of tweak,
all you want is that your car has equal amounts of grip left and right.
so, since grip is a nice formula; F = N* c where F is your grip, N is the tire load and c is the friction coefficient of the tire. when putting traction control on your tire actually you are making this c higher and thus giving more grip.
if the left tire has more grip than the right tire the car will be going sideways or turn when trothle is applied .
so that can come from many things, tweak, non-equal spring preloads and so on...
when your setting up your car do it in this order:
1 detweak your car using the method described a few posts above
2 balance your car using a balance tool like from xray. make sure your car has equal mass on left and right side, so if your running BL you'd have to add a little counter weight to the battery side
3 next, and this is kind of important, you should get equal loads on your tires.
disattach your four shocks from the suspension arms and leave hanging them on the shock tower
place a setup block under the front suspension. make sure its in line with the front tires. then you lift up the rear end with a 2mm imbus or anything with a sharp tip, make sure you lift it up in the center of the rear. now look at the distance between the tires and the setup board. if things aint equal you have to adjust your REAR downstop screws to get them equal. so if things are correct, your left and right tire come off the surface at the same time.
do this with the front suspension as well. this way you equalize the front suspension too.
4 now comes the tricky part
attach your front shocks and make sure the front suspension is settled by pushing down the front shock tower exactly in the middle a few times. now again get your 2mm imbus and lift the rear up again and again look if the tires come off equally. if not you'd have to adjust the FRONT shock collars. adjust them equally, so for instance if the rear left tire comes off earlier, you'd have to turn the left front shock collar counterclockwise and the front right shock clockwise. do this in small steps so you can get the front of the suspension precisely right.
in this way you use the rear suspension as a measuring device as it is totally straight because you've just straightend it with your downstops.
now attach your rear shocks and disattach your front shocks, turn your car around and do the same trick again
if you want your car to perform at its best you should do step 1, 3 and 4 before every run. this way you always have a balanced car.
tip, sometimes the uptravel of the suspension is not correctly achieved. sometimes the shocks are too short and act as a downstop instead of the downstopscrew. so if you're changing your cars downstop , check if the shocks are long enough for your new downstop setting. i had allot of trouble with this on my xray T2, untill i switched to TRF dampers, DUHHH
this setup tips for me were the difference between spot 9 in competition and top 3.
good luck!
Mark
very help full. but still dont understand the last part. uptravel. can explain.
Old 01-20-2008, 06:20 AM   #1092
Kenneth Tan's Avatar
Hi,
Anyone tried to flip the 415 1D block (front arm, rear piece) in front to clear the front belt? Does it work? What about 1C?
Kenneth Tan is offline   Reply With Quote
Old 01-20-2008, 06:43 AM   #1093
well, if you take the springs of the car and bolt the damper back on, you'd have a car with all the dampers on. now lift the car. it should be that the lower suspension arms rest on the downstop screw. but if the shock shaft is too short it will rest on the shock and therefore be much harder to setup. you have to use the downstop screw and not the dampers to set a maximum for the suspension travel...
mark
Markiempje is offline   Reply With Quote
Old 01-20-2008, 09:00 AM   #1094
fadzli's Avatar
mark
meaning that the when u lift the car, the screw should at least touch the chasis. is this what u mean?
Old 01-20-2008, 09:05 AM   #1095
yeah,
but my mistake, you can leave the springs on, they are not compressed anyways...
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
