Old 02-28-2013, 09:52 PM   #10576
rramjet's Avatar
Location: Everett WA in the Summer Mesa AZ in the Winter
I have just started running a 416X I bought used with the thin Exotek chassis in a Spec GT class on asphalt. Class limit is 21.5 motor, blinky ESC and no less than 5.5 FDR. I'm at 5.56. I'm running a Novak Ballistic with maximum motor timing and a MMP ESC with a Venom 5000 25C Lipo.
Car handles wonderfully but I'm getting my butt kicked on speed. The car has a Spec R gear transmission in the rear.
Can I still use the 2.055 internal ratio for calculating FDR with the Spec R setup?
rramjet is offline   Reply With Quote
Old 03-12-2013, 05:06 PM   #10577
Raman's Avatar
Trader Rating: 51 (100%+)
Yes the internal gear ratio should remain the same. When you say you're getting your butt kicked.. Do you mean you're out motored on the straight?
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 03-23-2013, 04:16 AM   #10578
Hi there guys,
Found this forum whilst googling for a 416 pinion. I've recently brought a 416 roller but struggling to find a pinion that meshes well. What pitch do the spurs have? I have a 70t spur and looking to put a BL system in and 50/50 drift, so was looking at like 17/18/19t pinion. Any help???
Much appreciated
Bowerz is offline   Reply With Quote
Old 04-04-2013, 12:52 PM   #10579
rramjet's Avatar
Sorry for the delayed response. I hate it when people do that.
Anyway, yes I was getting badly out motored on the straights. I put a Hacker Skalar 21.5 in and it took care of the problem. No gear change or anything else.
Thinking the Novak 21.5 needs some care and feeding. Interestingly I use the same motor with an 8.5 stator in another car and it gets up and goes. Only a little slower than 7.5s in the class.
Old 04-20-2013, 04:15 PM   #10580
Raman's Avatar
Originally Posted by Bowerz View Post
Hi there guys,
Much appreciated
With 17-19 pinion you will probably need a spur that's around 105 for it to mesh. I don't know what fdr is required for drift
Old 04-20-2013, 04:17 PM   #10581
Raman's Avatar
I think the Novak 21.5 is a bit slow.. I run it against silver cans in Mini class and am way under powered.
Old 06-05-2013, 08:04 PM   #10582
M3Man03's Avatar
Are there any other belts that work with the 416X? The one from the manual, 54143 seems to be pretty hard to find and was wondering if it was replaced with a different part #.
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 06-05-2013, 08:39 PM   #10583
Trader Rating: 22 (100%+)
Front or rear belt?
bjspinner is offline   Reply With Quote
Old 06-05-2013, 08:54 PM   #10584
Raman's Avatar
Its out of stock at Tamiya, not out of production. The 54143 is the low friction.. there is also 51343 which is the standard belt..
http://www.tamiyausa.com/items/radio...-(front)-51343
If you prefer the low friction, then it is in stock at amp draw
http://www.ampdraw.com/product.php?u...roductid=12524
If you are not in the US, then ebay / rcmart-dinball has it in stock as well
http://www.ebay.com/itm/Tamiya-54143...-/130546326058
Old 06-11-2013, 11:08 AM   #10585
Need a motor heat sink. What's tamiyas number for one. I need it ASAP
Leftynub is offline   Reply With Quote
Old 06-11-2013, 11:35 AM   #10586
Raman's Avatar
THere are a few
part number 9400448 (google as Tamiya 9400448) and you will see the image
http://www.tamiyausa.com/items/radio...-58371-9400448
Also 9400169
http://www.tamiyausa.com/items/radio...-58331-9400169
Part number 9415723
http://www.tamiyausa.com/items/radio...-58299-9415723
Old 10-23-2013, 02:30 PM   #10587
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
anyone know if the 417/417x/417/v5 chassis will bolt on to a 416?
JQ THE Car YE teknoV4/xerun150/t81400/savox1256tg
Tamiya TRF-416/s6040/vipervtx10R/ killshot 17.5
kyosho scr-sp/sanwa94770/hobbwing 90a/atomik 13.5
futaba 4pl
84 GT 5.0 is offline   Reply With Quote
Old 10-23-2013, 03:28 PM   #10588
Raman's Avatar
Nope
Old 10-23-2013, 10:08 PM   #10589
84 GT 5.0's Avatar
parts still readily available for this car?
futaba 4pl
Old 10-24-2013, 02:44 AM   #10590
Raman's Avatar
Yes they are. Sus arms are same ones used on 417. New ones from 418 will fit as well. Belts and pulleys are still in production
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
