Like Tree3Likes
Old 05-09-2012, 10:34 AM   #10546
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by JCarr View Post
Haven't seen anything about the Tamiya DCJ's, is nobody using them? I'm wondering if you have to mod the c-hubs to use them?
They work just fine and you dont have to grind anything to get them to fit or for clearance. They use a thinner inside bearing so everything clears.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 05-09-2012, 10:42 AM   #10547
JCarr's Avatar
Cool, thank you very much for the info Kevin. I was using the R1 lightweight uni's but had one snap on me a couple weeks ago. When the funds permit, I think I will get the Tamiya units.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 05-15-2012, 08:28 AM   #10548
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
I've been running the Spec-R gear diff in the rear of my 416 in MOD TC with a 4.5 motor. So far it seems to work fairly well for 2 weekends of racing. I have not had any major issues with leaking oil from the pulley, however I do notice that oil is coming out of the outdrives. I am using green slime on the case gasket. Should I be using something on the outdrive o-rings to seal it better? Right now I am using AE black grease on them.
Also on a sidenote, I installed the Spec-R CV2 dcj's and they have held up to 2 weekends of MOD. They have quickly developed slop, but they are still working. How often should I be rebuilding/replacing parts on the units?
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 05-21-2012, 01:16 PM   #10549
Raman's Avatar
Trader Rating: 56 (100%+)
Default 51333 rear up rights
The 51333 rear up rights have zero toe in correct?
The 51354 is the TB03 version with softer plastic right?
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 05-29-2012, 02:01 PM   #10550
Raman's Avatar
Anyone?
Old 05-29-2012, 02:06 PM   #10551
Trader Rating: 19 (100%+)
Anyone?
Yes you are correct.
Also remember that the softer plastic will last more high speed crashes then the carbon based parts because they give a little bit under pressure instead of just snap on impact the very first time.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 05-29-2012, 02:15 PM   #10552
Raman's Avatar
Thanks! The reason for my post was, I had my car on my set up station, and my rear toe in measured 4.5. In the rear, I'm running XA front, and D in back, which should give me 2.5. So I'm confused... Am I reading my set up station wrong? Do I have some mysterious rear uprights?
Old 05-29-2012, 02:59 PM   #10553
check EVERYTHING, make sure NOTHING is bent. When Tamiya was my main car i ran i learned that it was the most touchy car ever made, but as long as everything is on-point its untouchable really. Check all you bushings that go into the suspension holder, check the blocks themselves, check inner hingepins, outer hingepins and maybe just change your rear hubs, they may just be worn out. also check to make sure the arms arent worn out either.
★Randy Banks★
Old 05-30-2012, 12:38 PM   #10554
Raman's Avatar
Thanks for the input. Will do a check at home when things are calm. I was checking at the track and there are too many distractions when you are running 3 classes lol.
Old 07-07-2012, 09:13 AM   #10555
Trader Rating: 16 (100%+)
Hey guys, wil the spec-r spool for the 417 fit on the 416 worlds edition? Or is there anywhere that makes steel outdrives for the tamiya spool? Thanks!
this spool...
http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
samsking is offline   Reply With Quote
Old 07-07-2012, 07:57 PM   #10556
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
this spool...
that looks like the one I have in my 416x - but i know the x has narrower bulkheads (i thought that's what I read)...so worse case you might need some shims to get the spool where you want it
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-08-2012, 12:21 AM   #10557
CraigM's Avatar
Trader Rating: 34 (100%+)
No, 416 bulkhead widths are all the same. The 417 bulkheads are narrower than 416, but the bearing offset is the same between both cars
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-05-2012, 08:34 AM   #10558
syndr0me's Avatar
Are people still buying/running these things? I'm cleaning up 4 of them to sell. They've been collecting dust for a while and deserve to be on a track.
Also, I've got a used genuine Tamiya LiPo chassis in good shape I'm going to part with.
syndr0me is offline   Reply With Quote
Old 08-05-2012, 10:21 AM   #10559
k_bojar's Avatar
i happen to know of 2 people that just recently got one of these - and I'm one
a lipo chassis, eh? I'd be interested
Old 08-05-2012, 03:58 PM   #10560
Starteur's Avatar
You have PM
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer -Tamiya F-104X1 Formula 1 Racer.
Starteur is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
