Old 04-02-2012, 10:09 AM   #10516
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Is there a significant advantage in using the Tamiya Gear diff unit over the Spec-R units? I'd like to hear others' experience.
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 04-02-2012, 10:17 AM   #10517
For me the Tamiya Gear Diff Unit II is less leaky, and feels a lot smoother. But gives a bit more wear in the blades.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 04-02-2012, 11:13 AM   #10518
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Less leak, more smooth. I'd put a tamiya diff in the rear and use an old spec r for front diff (if you use it). The spec r is still decent and when using putty/heavy oil, it wont matter much anyways.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Old 04-02-2012, 05:58 PM   #10519
Potoczak's Avatar
Trader Rating: 111 (100%+)
Hey guys whats a good starting setup for the 416we?? I will be running 21.5 vintage class on a medium traction asphalt track.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 04-13-2012, 11:57 AM   #10520
tr1kstanc3's Avatar
What size 64p spur would I be looking at to get roughly a 3.5 FDR that fits well?
☆ Joe Tran ☆
Old 04-13-2012, 12:04 PM   #10521
Raman's Avatar
Trader Rating: 54 (100%+)
Either 82t spur with 48t pinion or 86t spur with 50t pinion
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 04-15-2012, 06:55 PM   #10522
PAPOSWING's Avatar
Hey does anyone know where I can find the tamiya 416 pivot block chart. One that describes what pivot block combination give you what for the front/ rear toe ect...
It is what it is....What i see is what you get.
The F1 Nation smack down city inc..
Food for thought; Rubbing is racing, hacking is not. ....Hacking is for the lazy.
Cheating is for losers!
PAPOSWING is offline   Reply With Quote
Old 04-15-2012, 07:01 PM   #10523
Trader Rating: 37 (100%+)
There's one on Tamiya's site as well as a few others floating around...
http://www.tamiyausa.com/articles/fe...article-id=412
Nexus is offline   Reply With Quote
Old 04-15-2012, 07:16 PM   #10524
PAPOSWING's Avatar
Awesome dude thanks..
Old 04-21-2012, 11:30 AM   #10525
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
I'm stumped. New to the Tamiya and experiencing an issue with the 416x. This is my 2nd season doing on-road.
Running a Futaba 4pk with my epa set at 120 left and right but I am not even near full lock. On the Hudy setup station I have 15 degrees of steering each way. The steering will go to full lock freely with the radio off. If this is how 416x is, that's fine... or I just need more travel out of the radio (which I don't have).
Here's a couple pics.
Tamiya TRF416 / TRF416WE / TRF416X-lock-large-.jpg   Tamiya TRF416 / TRF416WE / TRF416X-center-large-.jpg
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 04-21-2012, 01:31 PM   #10526
Trader Rating: 69 (100%+)
Have you tried using a different servo horn that is longer, i.e., making the distance betweenthe servo center and servo link longer for a wider sweep? That can increase your steering angle quite a bit.
eComet is offline   Reply With Quote
Old 04-21-2012, 01:52 PM   #10527
Yeti AS3's Avatar
I'm using an xray servo saver. I have about .75mm between the link and top deck. I just checked my bros tc6 has about 17 degrees...so its not too far off
Hot Bodies D413
AE B5m
Old 04-21-2012, 07:37 PM   #10528
It has to be the servo horn since it goes full lock without it. I heard it ran full lock and dual rate down to 80% in the past.
Old 04-22-2012, 09:15 AM   #10529
Trader Rating: 19 (100%+)
My Xray only has 17* my 416 has 15* with an xray servo saver on it, and i have never had a problem. The car has enough steering already really. If you need more steering when going through a corner you should just make an adjustment to the car to get that little bit extra.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 04-22-2012, 03:08 PM   #10530
Yeti AS3's Avatar
I finally figured it out. I used the tallest hole on the xray servo saver and only running 2mm washers under the center link on the steeing rack. I have a hair over 17deg now.
Hot Bodies D413
AE B5m
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
