Tamiya TRF416 / TRF416WE / TRF416X
#1036
Tamiya many parts no stock !
#1037
#1038
I'm sure you are waiting for an actual spool made for the 416
#1040
I never run the bushing when on carpet... Mainly came from a tip supplied to me when David Spashett was running the car. He recomended removing them from the shocks, as the reduce the pack in the shock, effectively smoothing out the action. It's a quick change to make, so give it a try for yourself
As for the C-Hubs. No, the 05MS ones are the same as the 415. The TA05 IFS does use the same types, but in a plastic, rather than graphite material.
If you want to get close, try 415 C-hubs, but with HPI front knuckles. It puts the axle at the same height as the 416, but the steering link ball joint is moved in and forward slightly.
I was running that combo today, as my spares hadn't arrived in time.... worked fine
#1041
Try PrecisionRC. I just ordered a bunch of 416 parts from them over the weekend. Hopefully it'll be here before Sunday. I broke my CHubs and had to use 415 CHubs for the time being. Maybe try EBay as well. I'm not sure when TowerHobbies will have them in stock. But they do have them listed. Try RCModel, RCMarket, Rainbowten, RCChamp, etc.
For chassis tweak, are you asking about 416 chassis tweak? If so, I find this chassis very very hard to tweak.
#1042
Does anyone know if any companies make aluminum 4 degree C-hubs and\or aluminum 0 degree rear uprights for the 416?
#1043
not yet, but you can be sure thet Square will soon be making one....
#1044
I've been breaking the composite chubs pretty easily, so I wouldn't mind seeing if aluminum ones cut down on the breakage without transferring too much energy to something else.
I bought some of the non-composite chubs by accident, and decided to give them a try, even though they're quite flexible. It seems to have cut down on the breakage, and given the car a little more steering as well.
#1045
#1046
Hello Guys,
Attached my set-up from DHI Cup last weekend.
Marc's set-up was same, Viktor only used 0.5mm rollcenter shims and front 0.5mm anti-dive.
Jilles
Jilles
#1047
#1048
Thanks Jilles!!!
Do you remember the upper arm spacers in front?
Very happy to see you at the blue team! :-)
#1049
Hey Jilles,
Congratulations with your first Tamiya result.
I'm sure that with the Tamiya, you can win the World Championship!
David
David
#1050
Will the david jun suspension fit on the 416?
