Old 02-01-2012, 11:36 AM   #10471
I personally like the Tamiya Gear Diff Unit II the most, as it is smoother and less leaky (from my experience). But you may see increased wear on the blades when using the Tamiya diff instead of the Spec-R diff.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-06-2012, 06:13 PM   #10472
Raman's Avatar
Trader Rating: 49 (100%+)
Default Toe Angle Rear Upright
Do the 51333 Rear Upright have a pre-set toe angle?
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 02-07-2012, 12:12 AM   #10473
Pro10noob's Avatar
No they don't have a toe in angle as this is done using your suspensionmounts.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 02-08-2012, 07:30 AM   #10474
JCarr's Avatar
What would the difference in handeling be between using 1xa/1d on the rear of the car for a 2.5* toe vs using 1a/1d with 1* uprights to get 2.5* total toe? What i am trying to to is combat a loose condition going into the the turn. Thanks for any advice.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 02-08-2012, 01:22 PM   #10475
CraigM's Avatar
Trader Rating: 34 (100%+)
You will have a wider rear track which will likely make your car worse.
Try run anti dive up front or less rear droop
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-08-2012, 01:29 PM   #10476
JCarr's Avatar
Thank you very much for the reply, I had a feeling that would be going in the wrong direction, but was confused. I'm running 1mm droop in the rear now, perhaps i will try the anti dive and see if that helps.
Gorilla Size Racing
Old 02-08-2012, 01:39 PM   #10477
Raman's Avatar
I always get confused with Anti dive.. The shim goes under the inner or outer block?
Old 02-08-2012, 01:49 PM   #10478
Trader Rating: 69 (100%+)
Anti-dive means the front of the arm points more downward than the rear. So this means adding shim to the front inner block to raise it up higher than the front out block. Pro-dive is the other way.
eComet is offline   Reply With Quote
Old 02-08-2012, 11:02 PM   #10479
CraigM's Avatar
If you post your full setup then I can suggest a few more things that might help
Old 02-09-2012, 05:54 AM   #10480
JCarr's Avatar
Thanks, I don't have it written down, but things I can remember of the top of my head....
Front: 0 toe, c/c suspension blocks flat on chassis, blue assc. springs, 50wt oil, 1.5* camber, 4* caster.
Rear: 2.5* toe, 1xa/1d blocks flat on chassis, green assc. springs, 35wt oil, 1.5* camber
Tire: solaris med
Motor: navak ss 21.5 USGT class
Thanks for you time and thoughts.
Gorilla Size Racing
Old 02-09-2012, 06:20 AM   #10481
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Tire: solaris med
I'm assuming this is for carpet:
Scrap the Associated Springs and weird oils. Go to Tamiya Blue and white and use something like 40wt all the way around. Go back to 3 degrees of rear toe.
Jilles Groskamp's Snowbirds 2010 setup is the best place to start for the 416X.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Old 02-09-2012, 06:46 AM   #10482
JCarr's Avatar
Yes it is on carpet, low/med bite. I'm not 100% sure on the front oil i would need to open the shock to check, but it is 50 or 40. I had the tamiya springs on it for a while and it was really hard to control, but that was a good while ago and I have changed quite a few things since then, I can try them again. I need to order the E and F blocks so i can get more toe in the rear or I could use the 1* uprights that i have.
Gorilla Size Racing
Old 02-09-2012, 11:01 AM   #10483
Trader Rating: 26 (100%+)
Does anyone know the part number for the Tamiya White Springs?
Steve Boice
Sponsored by: Speedmerchant, Trinity/Revtech, Destiny, Protoform, Hobbywing USA, KO Propo, Ulti, Xenon, TQ Wire
Hyperform racing--In memory of Lino
Bigdaddyswank is offline   Reply With Quote
Old 02-09-2012, 11:11 AM   #10484
Trader Rating: 36 (100%+)
RC On Road Tuned Spring Set - White
Item #49382
Nexus is offline   Reply With Quote
Old 02-09-2012, 12:58 PM   #10485
CraigM's Avatar
Tire: solaris med
Agree with Dane's comments, tho 2.5deg toe is fine for slower classes. What body do you run and what shims do you have on the bulkheads and uprights?
In addition to the tamiya springs I would start by raising all of the suspension blocks except the FF block by .5mm, which will raise your RC all round making the car more stable and giving more corner speed, and will give you the antidive I mentioned which will aid stability under brakes.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
