Like Tree3Likes
Old 02-04-2011, 06:08 AM   #10231
CuLeX's Avatar
Questions??
Hi all,
for the 416x..if i'm using 1mm wheel spacers front and 0.5mm spacers rear will it give it more steering or otherwise? or its better to use 0.5mm front & rear?
CuLeX is offline   Reply With Quote
Old 02-04-2011, 12:09 PM   #10232
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Default Litemodz driveshaft
Is it worth the money in performance?
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 02-04-2011, 12:22 PM   #10233
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Read the Litemodz thread, not many happy customers.
I got a set... broke within 2 laps.... $100 wasted.
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 02-04-2011, 12:33 PM   #10234
jonest's Avatar
I have mine on couple of packs with it... so far it's ok.... gonna save it for TITC....
jonest is offline   Reply With Quote
Old 02-04-2011, 12:44 PM   #10235
g12314's Avatar
I hope you have better luck then I did... Mine failed using a 25.5, so they definitely were not robust.
Old 02-04-2011, 12:53 PM   #10236
jonest's Avatar
Were running 5.5t on turbo esc.... however felt like there's some binding when turning the servo (esc off)....
Old 02-04-2011, 03:33 PM   #10237
guinnes.s's Avatar
what other good options then,any suggestions?
thanx
guinnes.s is offline   Reply With Quote
Old 02-04-2011, 05:36 PM   #10238
hana166's Avatar
I have a set of Team C ECS shafts in the front.. I heard they were rubbish but so far so good. But they're cheap enough. Car handles really well with them
If they don't work out I'm gonna try the TRF417 axles as the locking grub screw will not be needed which should help steering as the pin floats. Use steel bones up front they are super reliable, I've used the same set in my Mi4 and Photon they lasted six months before finally wearing out.
The standard Litemodz shaft is ok in the back as there is less stress. Ok if you need to lose 10g. Std or CVS are a complete disaster in the front..you'll have to throw them away the first day. That is of course assuming your order ever arrives..
hana166 is offline   Reply With Quote
Old 02-05-2011, 10:16 AM   #10239
Question in regards to chassis flex. I'm running the 416 and it seems to want to snap going in and then comming out of a corner. I check it on the bench and there is quite some flex compared to my tc5. Is this normal or is the chassis past its life.
THANKS FOR YOUR HELP.
Friulimotosport is offline   Reply With Quote
Old 02-05-2011, 11:31 AM   #10240
Foxxrocket's Avatar
Could be chassis tweak.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 02-06-2011, 05:28 AM   #10241
Tor Erik's Avatar
R/C Tech Charter Subscriber
About gear diff in Tamiya 416......
Have tested like you suggested Kevin K, but it did not help
I have given up the gear diff. Once I did put in the old ball diff my car was very good !
PS I am running mod 4,5 turn, think the gear diff might be ok in stock.
Xray XB4 and T4 Futaba 4PK
Tor Erik is offline   Reply With Quote
Old 02-06-2011, 07:05 AM   #10242
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Wow thats a bummer....I know that on some of the setup sheet that Marc and Jillies are both running gear diffs in their cars and they only run mod. So maybe something else is going on with the diff? Maybe you need thicker or thiner oil like other suggested? It would be something to play with when you have more time.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 02-06-2011, 07:58 AM   #10243
guinnes.s's Avatar
ok a simple question,my spool outdrives are not in good shape and i was thinking to glue together a diff and make it work like a spool.
would it work?
thanx
Old 02-06-2011, 08:43 AM   #10244
I ran a gear diff all summer long with a 5.5 and it worked great. I used 1000 wt oil.
M3dreamin2008 is offline   Reply With Quote
Old 02-06-2011, 08:45 AM   #10245
has anyone used the white belts on the 416x?
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
