Old 01-25-2011, 08:02 AM   #10201
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Originally Posted by Markus View Post
I have to believe Tamiya released the 416x Lipo chassis and then discontinued it to boost the sale of the new 417. (everyone would just get the upgrade chassis.)
I have the Tamiya lipo chassis and it balances perfectly on balance dots without any additional weights. I have added two 7gram weights to the sides of the steering rack to make our legal weight (1380). mine weights in at 1384 race ready.
Markus, that is what I believe too, but you know, I bought the car last year when it was released, the day it went into sales at rcmodel I placed the order and I really don't want to go for the 417 just because of that.
I am looking now at getting the Exotek or the Smokem, doesn't make me happy because I like to use original stuff on my cars but seems that it is the only way to go now.
If someone knows or want to sell this upgrade kit PM me.
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 01-25-2011, 08:04 AM   #10202
jonest's Avatar
Originally Posted by COLD AS ICE View Post
this may sound like a stupid question but why does the 416 seem to shred rear belts so much in modified touring?
ru using gear diff or ball diff? If it's gear diff, u need to set the belt tighter than the ball diff. Otherwise, replace worn pulleys as worn pulleys would wear belt faster. And do check the pulleys shimming (left / right)
Hope this helps.
jonest is offline   Reply With Quote
Old 01-25-2011, 12:45 PM   #10203
Trader Rating: 19 (100%+)
I run a ball dif and the pulleys don't seem to be worn out next to check is spacing. Are you saying that my center layshaft should be centered in the car?
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 01-26-2011, 04:24 AM   #10204
Fabricio's Avatar
Default Lipo chassis upgrade
Well seems that I am not going to be able to get hold of a Tamiya Lipo Upgrade Kit.
Tried in all stores and all were out of stock, sent emails for a couple of them but all of them have returned to me saying they do not have a precise information if they are going to have it back in stock, shame.
Now my 2 options:
- Exotek
- Smokem.
I would like to have some opinions about those 2 brands and if someone have tried them post your comments about the performance.
I am really interested on the Exotek one, as it comes with those metal weights so you don't need to add too much lead and it also helps the lipo to stay in place.
Let me know your thoughts.
Old 01-26-2011, 07:01 AM   #10205
5tylez's Avatar
does anyone know of the 416x Lipo chassis & the 417 chassis have the same screw hole positions?
I want to try 417 chassis on a 416x.
5tylez is offline   Reply With Quote
Old 01-26-2011, 07:06 AM   #10206
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
No the 417 chassis is different.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 01-26-2011, 07:43 AM   #10207
H.N.'s Avatar
Is this confirmed? I have a buddy that has both 417 and 416 swears that it will fit and all the holes lines up.
H.N. is offline   Reply With Quote
Old 01-26-2011, 07:55 AM   #10208
I had both the exotek and the 417 and no the screw holes don't line up.
Regarding the exotek chassis. I thought it was really nice. Not sure why people dislike the graphite servo arm. It holds the servo in place just fine and sits high enough where there's no chance of rubbing. I personally prefer the servo arm over the little bump that's on the smokem and tamiya chassis. I've been tempted to grind off the bump and use a servo tape + inner servo mount combo.
malkiy is offline   Reply With Quote
Old 01-26-2011, 08:32 AM   #10209
TryHard's Avatar
Your buddy needs to look again.. no hope in hell of the screws lining up!
Old 01-28-2011, 05:11 PM   #10210
guinnes.s's Avatar
what is the difference between the original 416 and the 416x?
thanx
guinnes.s is offline   Reply With Quote
Old 01-28-2011, 05:11 PM   #10211
guinnes.s's Avatar
can i convert my 416 to 416x????
thanx
Old 01-28-2011, 06:01 PM   #10212
Ray k's Avatar
Trader Rating: 46 (98%+)
The first three cars are , and major highlights
416 ,the start
416we, improved top deck and chassis with battery position change, improved front motor mount foot,but motor position the same the 416
416x, narrower front track width ,motor mount position 1mm inward, redesign lower bulk head to change rear flex, rear diff moved back 1.8 mm
Ray k is offline   Reply With Quote
Old 01-30-2011, 09:36 PM   #10213
Blueman Austria's Avatar
Hy!
Dose anyone know if the 415 spool cups (white ones) also fit the 416, or the 416 black ones the 415? Of course with the matching sleeves.
greetings Blueman.
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 01-31-2011, 03:37 AM   #10214
guinnes.s's Avatar
need some explanations regarding droop.
i m looking at this setup http://www.petitrc.com/reglages/tami...buryNOWRd3.pdfand if i have 6.5mm on the front of droop no way i can get 5mm on the ride height,the max i can go is 3.5mm.
what mi missing??
thanx
Old 01-31-2011, 07:33 AM   #10215
what mi missing??
thanx
I assume you are using a droop gauge? If you are, where are you measuring your droop?
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
